[OpenLayers-Users] IE7 and Firefox draws icons to different places
Andreas Hocevar ahocevar at opengeo.org
Sun May 23 05:49:15 EDT 2010
this could be a VML renderer bug. But to investigate, I'd ask you to provide a minimal example showing the issue.
Thanks,
Andreas.
On May 21, 2010, at 11:01 , ahlah wrote:
> Hi,
> I have some icons in my map ponting to interesting places. Points are
> vector features and icon path is in styleparameters of the feature. There is
> also graphicWidth and graphicHeight values but no graphicXOffset and no
> graphicYOffset in styleparameters.
> Left picture is from Firefox and right one from IE7. Popup points to the
> coordinate point of the feature correctly and Firefox draws the icon to
> correct place. In IE7 X axis is correct but Y is in different place, the
> offset doesn't depend on zoomlevel, it is always the same (In pixels). Am I
> doing something wrong or is this known problem with IE. Should I check which
> browser is in use and put some offset to style parameters in IE7?
> Br,
> ahlah
> http://n2.nabble.com/file/n5083376/ff.jpg
> http://n2.nabble.com/file/n5083376/IE7.jpg
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/IE7-and-Firefox-draws-icons-to-different-places-tp5083376p5083376.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
