[OpenLayers-Users] Custom Layer From Non Standard Map Server
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Tue Jul 5 08:06:49 EDT 2011
I would suggest starting with copying OpenLayers.Layer.WMS and adapting it
to your needs.
If you only need singleTile and not a gridded layer, you could also
inherit from OpenLayers.Layer.HTTPRequest.
Best regards,
Bart
> Hi OpenLayers users
> I want to create some Layer for some kind of map server. This is not Tile
> server or WMS. I don't know is this posiible with OpenLayers so I ask
> first.
> The server is accepting the following url parameters:
> xRes=800&yRes=600&latTopLeft=50.0&lonTopLeft=0.0&latBottomRight=20.0&lonBottomRight=40
> So we have such variables:
> xRes - this is the returning image width in pixels
> yRes - this is the returning image height in pixels
> latTopLeft - latitude in degrees of the top left corner of the returned
> image
> lonTopLeft - longitude in degrees of the top left corner of the returned
> image
> latBottomRight - latitude in degrees of the bottom right corner of the
> returned image
> lonBottomRight - longitude in degrees of the bottom right corner of the
> returned image
> The server returning png image in dimensions specified in parameters xRes
> and yRes.
> Now I want To use it in OpenLayers Map. Does somebody can help me start
> with
> this. What OpenLayer.Layer class should I extend for this server?
> http://osgeo-org.1803224.n2.nabble.com/Custom-Layer-From-Non-Standard-Map-Server-tp6549456p6549456.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
