[OpenLayers-Users] Transform Points Help
Bart van den Eijnden bartvde at opengeo.org
Tue Aug 7 01:02:19 PDT 2012
Just go to spatialreference.org and look for the definition:
http://spatialreference.org/ref/epsg/4283/proj4js/
Best regards,
Bart
OpenGeo - http://opengeo.org
Expert service straight from the developers.
On Aug 7, 2012, at 9:59 AM, Riaan Lombaard <rlombaard at maxgeo.com> wrote:
> Hi,
> Thanks for the advice.
> I am looking at using proj4js.
> But it seems like GDA94 is not supported by them. I might be mistaken but look at "proj4js\lib\defs" directory and you will  not find EPSG4283 .
> Riaan
> From: openlayers-users-bounces at lists.osgeo.org [mailto:openlayers-users-bounces at lists.osgeo.org] On Behalf Of Alexandre Dubé
> Sent: 01 August 2012 02:10 PM
> To: openlayers-users at lists.osgeo.org
> Subject: Re: [OpenLayers-Users] Transform Points Help
> Hi Riaan,
>   In the console, if you inspect OpenLayers.Projections.transforms, you'll see which projection codes are natively supported in OpenLayers.  If yours is not there, then you need to include the Proj4js library and add the ones you want :
>   http://trac.osgeo.org/proj4js/wiki/UserGuide
> HTH,
> Alexandre
> On 12-08-01 07:42 AM, Riaan Lombaard wrote:
> Hi,
> I need some transformation advice.
> Running this script in Firebug.
> var point = new OpenLayers.Geometry.Point(128.627103622948, -15.8249150838119);
> var point_transformed = point.transform(new OpenLayers.Projection("EPSG:4283"), new OpenLayers.Projection("EPSG:4269"));
> console.log(point);
> console.log(point_transformed)
> What happens is the data I am getting is from `GDA94 (SRID 4283)` and I need convert it to ` WGS84 (SRID 4326)` for the map base layer I am using `http://vmap0.tiles.osgeo.org/wms/vmap0`
> But looking at the example it does not seem to convert anything, the x,y stay's the same?
> What am I missing?
> Riaan
> Users mailing list
> Users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/openlayers-users
> Alexandre Dubé
> Mapgears
> www.mapgears.com
> Users mailing list
URL: <http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120807/52724b78/attachment-0001.html>
