[OpenLayers-Users] Using ArcGIS as a mapping server with OpenLayers
Leon D'mello
leondmello at gmail.com
Fri Feb 10 05:57:41 EST 2012
Hello All,
I want to you an ArcGIS server as a mapping server do display a layer of
data points on a layer of Bing maps.
Although I'm unable to successfully get the ArcGIS layer over the Bing
Layer.
Here is the JavaScript I am trying to accomplish the task with,
var map;
function init() {
map = new OpenLayers.Map('map_element', {
maxExtent: new OpenLayers.Bounds(-174, 18.4, -63.5, 71),
maxResolution: 0.25,
projection: "EPSG:4326"
var BingMap = new OpenLayers.Layer.VirtualEarth(
"Bing Maps",
{ type: VEMapStyle.Shaded },
{ displayInLayerSwitcher: false }
var data_points = new OpenLayers.Layer.ArcGIS93Rest(
'Customers',
http://sqlsrvr:9595/ArcGIS/rest/services/CustomersCanada/MapServer/export',
layers: "0",
TRANSPARENT: true
isBaseLayer: false,
extractAttributes: true,
opacity:.5
map.addLayers([BingMap,data_points]);
map.addControl(new OpenLayers.Control.LayerSwitcher({}));
if (!map.getCenter()) {
map.zoomTo(1);
I tried searching on the net but to no avail. Anyone here to help me out?
Thanks,
Leon Dmello.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20120210/ef84966f/attachment.html
