[OpenLayers-Users] Obtain info from the user defined polygon
Phil Scadden p.scadden at gns.cri.nz
Tue Jun 12 17:13:54 PDT 2012
Here is how I do it. Sorry, but there is a lot of application-specific
stuff in it. (I have a structure that stores a lot of metadata about how
a layer is to be displayed and queried).
                 pySelCtrl = new
OpenLayers.Control.DrawFeature(selectedLayer, OpenLayers.Handler.Polygon, {
                     geodesic: true,
                     handlerOptions: {
                         citeCompliant: false
                 }); // selected layer is an empty vector layer that use
for drawing selected feature on and for drawing control
                 pySelCtrl.events.register("featureadded", this,
function (e) {
                     clearData(); // housekeeping (clean up previous
queries, delete all vectors from selectedLayer)
                     var pfilter = new OpenLayers.Filter.Spatial({
                             type: OpenLayers.Filter.Spatial.INTERSECTS,
                             value: e.feature.geometry
//                    This next piece of code is using application logic
to find out which fields to fetch back from the server. If you dont
specify properynames, it will return all of them
                     var propNames = [];
                     var layerNode = getLayerNode(combo.value); // this
returns application metadata about the layer to query
                     var spatialQueryNode =layerNode.spatialQuery[0]; //
get the list of fields to return from application metadata
                     for (var i = 0; i < spatialQueryNode.fields.length;
i++) {
                         propNames.push(spatialQueryNode.fields[i].id);
                    if (spatialQueryNode.highlightOnMap)
propNames.push("SHAPE");     // fetch back geometryif I am going to draw
the on the map
// This read queries the server.
                     wfsProtocol[combo.value].read({
                         filter:  pfilter,
                         propertyNames:propNames,
                         callback: processSpatialQuery,
                         scope: strategy
The processSpatialQuery callback unpacks the returned GML to populate a
popup, draws the selected features in selectedLayer etc.
Notice: This email and any attachments are confidential. If received in error please destroy and immediately notify us. Do not copy or disclose the contents.
