[OpenLayers-Users] Polygon Layer Projection
Diego Guidi diegoguidi at gmail.com
Fri Oct 12 06:51:22 PDT 2012
> I have the map projection set to EPSG:4326 (does not seem to make a
> difference whether it's 4326 or Google's 900913).
> I have loaded Google layers (OpenLayers.Layer.Google).
AFAIK as I know, if you add this kind of layer, your map goes to
google projection, so you need to add data in 900913 (or translate
them).
