[pgrouting-dev] My questions again:-)
Mario Ködding dev-mario at web.de
Fri Feb 18 06:18:38 EST 2011
Hi Markus,
osm2pgrouting loads a lot of data into memory. The reason for the
termination of the script could be, that your system runs out of memory. You
should try to observe your system's memory usage while the script is running
and e.g. use Bremen.osm instead of Bayern.osm in a first step.
Best regards
Mario
On Fri, Feb 18, 2011 at 11:59 AM, Hens,Markus M.
<m.hens at student.fontys.nl>wrote:
> Hey,
> I try to ask my questions again:-)
> 1.
> when I try to import Bayern.osm or Germany.osm with osm2pgrouting, the
> script stops when Trying to load the data and trying to parse the data. Is
> that a common error?
> Barcelona.osm from the workshop works with no problems. Did I forgot
> anything?
> 2.
> I played a little bit around with OSGEO live tools.
> I Understand that mapconfig.xml defines the relevant tags and that you have
> to add costs to these tags.
> I did not understand if for example a way has a tag bridge=yes and a tag
> highway=motorway this way is saved two times in the db because every way has
> only one class_id.
> how is it handled if there are two relevant tags for one way?
> Best regards,
> Markus_______________________________________________
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110218/80858a7f/attachment.html
More information about the pgrouting-dev mailing list
