[pgrouting-dev] Re: My questions again:-)
Jordan Anderson jordandrsn at gmail.com
Fri Feb 18 10:23:56 EST 2011
Hi Markus,
osm2pgrouting also loads data into a table called way_tag that
maintains the relationships between ways and multiple tags.
Thanks,
Jordan
> Date: Fri, 18 Feb 2011 11:59:16 +0100
> From: "Hens,Markus M." <m.hens at student.fontys.nl>
> Subject: [pgrouting-dev] My questions again:-)
> To: "pgrouting-dev at lists.osgeo.org" <pgrouting-dev at lists.osgeo.org>
> Message-ID:
>        <7F35DC3EAB7D654E8F74E5EA41A7EA07B3103DB59B at MOLDAU.medewerker.fontys.local>
> Content-Type: text/plain; charset="us-ascii"
> Hey,
> I try to ask my questions again:-)
> 1.
> when I try to import Bayern.osm or Germany.osm with osm2pgrouting, the script stops when Trying to load the data and trying to parse the data. Is that a common error?
> Barcelona.osm from the workshop works with no problems. Did I forgot anything?
> 2.
> I played a little bit around with OSGEO live tools.
> I Understand that mapconfig.xml defines the relevant tags and that you have to add costs to these tags.
> I did not understand if for example a way has a tag bridge=yes and a tag highway=motorway this way is saved two times in the db because every way has only one class_id.
> how is it handled if there are two relevant tags for one way?
> Best regards,
> Markus
More information about the pgrouting-dev mailing list
