[pgrouting-dev] Ask about road table in routing.
viet bui buiviet9488 at gmail.com
Fri Jun 3 04:13:48 EDT 2011
I'm using pgrouting 8.3 version. and i found an website that show me how to
routing using pgrouting and postgis.
that a good information for me to do my work.
but, when i follow the SQL file script, and insert data to Road table. I
don't clearly know about each fields in Road table.
can you show me the definition of each field and the meaning of it.
for example :
Fields  ---- meaning
id  --  get the id of each point.
 source -- .....smth.....
 target -- ....
 cost -- ....
 reverse_cost --- .....
 sens ----- .....
 x1 ----- ......
 y1------ .....
 x2 ------......
 y2 ------ ......
 edge_id ----- .......
 the_geom ------.....................
thanks.
*Mr. Vietbv*
*Do your best , the rest will come**.*
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110603/34b25a02/attachment.html
More information about the pgrouting-dev mailing list
