[pgrouting-dev] Support for Time Constraints
Daniel Kastl daniel at georepublic.de
Sun Jun 12 22:26:46 EDT 2011
Jay, there should be more tables.
So something goes wrong with osm2pgrouitng. but from your output I can't
guess what it is.
Can you give some details (maybe in a new thread)
Daniel
> Well in the US anyway. Also if this is OSM data then you might get a better
>> clue on classes by looking to that .... OH!, look what I found in google :)
>> http://workshop.pgrouting.org/chapters/advanced.html
> Hi Steve,
> Thanks for giving me the link. I somehow never tried doing advanced part of
> the workshop.
> Well, it is using routing database which we generate during this step:
> http://workshop.pgrouting.org/chapters/osm2pgrouting.html
> I am doing exact steps outlined there but unfortunately, after I run
> osmtopgrouting command,  get following output:
> <lots of mesages regarding different class name, and ids>
> class name = roundabout
> class id = 401
> class id = 401 name = roundabout added to type name=junction
> Trying to load data
> Trying to parse data
> I find only the following 3 tables generated in routing database:
>                List of relations
>  Schema |       Name        | Type  |  Owner
>  public | geography_columns | view  | postgres
>  public | geometry_columns  | table | postgres
>  public | spatial_ref_sys   | table | postgres
> (3 rows)
> The tutorial says a total of 8 tables should be generated.
> I do not get any other warning or error messages.
> On other hand, I am able to do all steps here:
> http://workshop.pgrouting.org/chapters/topology.html correctly, and hence
> till now I was working with pgrouting-workshop database.
> I am sorry if this are very silly errors, but I have no previous experience
> working with such data. Any hint/link why I am not able to generate routing
> database?
>> Looks like first digit is type and the three digits are from the classes
>> table.
>> -Steve
>> On 6/12/2011 4:33 AM, Jay Mahadeokar wrote:
>>> On Sun, Jun 12, 2011 at 1:32 PM, Anton Patrushev
>>> <anton.patrushev at georepublic.de <mailto:anton.patrushev at georepublic.de>>
>>> wrote:
>>>    Hi Jay,
>>>    No, there was no specific meaning, just king of cyphering - first
>>>    digit for road class and then two last digits for road type.
>>> Hi Anton,
>>> So, as you said last 2 digits are for road type. I can see they are
>>> mainly 00, 01, 02, 06, 08, 09, 10, 11, 12 ,14, 17.
>>> Road class is just 1 or 4.
>>> Can I differentiate major highways, minor highways, streets etc using
>>> this info?
>>>    Anton.
>>>    On 6/12/11, Jay Mahadeokar <jai.mahadeokar at gmail.com
>>>    <mailto:jai.mahadeokar at gmail.com>> wrote:
>>>     >> Hi Jay,
>>>     >> I think that instead of just random times, I would take a
>>> different
>>>     >> approach to generate this data. If we think about "rush hour"
>>>    around a
>>>     >> major
>>>     >> city, the highways (based on road class) flowing into the city
>>>    in the
>>>     >> morning would get reduced average speeds you could apply curve
>>> like
>>>     >> average
>>>     >> speed*percent based on 6am (90%), 7am(75%), 8am(45%), 9am(50%),
>>>    10am(85%)
>>>     >> and do something similar in the evening rush. It might be too
>>>    hard to
>>>     >> figure
>>>     >> on direction of flow in/out bound so apply the curve to all
>>>    traffic. The
>>>     >> assumption is that the highways are congested which will force
>>>    traffic
>>>     >> onto
>>>     >> side streets. You might want to also reduce the lower class
>>>    speeds by say
>>>     >> a
>>>     >> constant 80% during rush hour.
>>>     >> If we can get OSM data then it should be easy to populate the
>>>    table with
>>>     >> that data.
>>>     >> -Steve
>>>     > I am trying to write plpgsql query to generate time-dependent data
>>>     > corresponding to the ways table in pgrouting workshop. As
>>>    suggested by Steve
>>>     > above, instead of generating random data, I will follow patterns
>>>    (see above
>>>     > message) so that the data is nearer to the real worlds scenario.
>>>     > So, now I need to make distinction between highways, streets etc.
>>>    I saw the
>>>     > attribute class_id in ways table. It has 14 distinct values:
>>>     >  class_id
>>>     > 102
>>>     > 122
>>>     > 106
>>>     > 111
>>>     > 108
>>>     > 100
>>>     > 109
>>>     > 112
>>>     > 101
>>>     > 110
>>>     > 401
>>>     > 119
>>>     > 117
>>>     >       114
>>>     > Any specific meaning attached to these values? I did not find any
>>>     > information on the pgRouting-workshop website [1].
>>>     > Thanks in advance.
>>>     > [1] http://workshop.pgrouting.org/chapters/topology.html
>>>     > Regards,
>>>     > -Jay Mahadeokar
>>>    Georepublic UG (haftungsbeschränkt)
>>>    Salzmannstraße 44,
>>>    81739 München, Germany
>>>    Anton Patrushev
>>>    CTO
>>>    eMail: anton.patrushev at georepublic.de
>>>    Web: http://georepublic.de
>>>    Tel: +49 (089) 420 959 519
>>>    Sip: 1959519 at sipgate.de <mailto:1959519 at sipgate.de>
>>>    Commercial register: Amtsgericht München, HRB 181428
>>>    CEO: Daniel Kastl
>>>    _______________________________________________
>>>    pgrouting-dev mailing list
>>>    pgrouting-dev at lists.osgeo.org <mailto:pgrouting-dev at lists.osgeo.org>
>>>    http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>>> Regards,
>>> -Jay Mahadeokar
> Regards,
> -Jay Mahadeokar
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
URL: http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20110613/13473b26/attachment-0001.html
More information about the pgrouting-dev mailing list
