[pgrouting-dev] Routing instructions/Nav directions on pgRouting
Paulo Figueiras paf at uninova.pt
Thu Nov 28 06:42:55 PST 2013
Hello, Daniel.
Thank you for your quick reply. Well, for now I wouldn't want to enrol
myself in such an endeavor :) . I would prefer to use something that is
already done, even if it is much simpler than other routing engines'
driving instructions.
I was reading one thread of your mailing list where you guys talk about the
solution presented by Stephen Woodbridge, using iMapTools, and I was
wondering if Stephen's algorithm is accessible for use, or if it is a
private solution.
Do you know anything about this subject? Thank you very much.
Regards,
Paulo.
2013/11/28 Daniel Kastl <daniel at georepublic.de>
> On Thu, Nov 28, 2013 at 8:43 PM, Paulo Figueiras <paf at uninova.pt> wrote:
>> Greetings.
>> I am a portuguese developer and I just started using pgRouting as my
>> routing engine. I chose it because it is very flexible and scalable, and it
>> is based on a relational database.
>> This offers me other types of functionalities that normal routing engines
>> don't.
>> Even so, I need a higher-level functionality, namely route instructions
>> or navigation directions, that pgRouting does not provide for now (I think).
>> I read some forum posts from people that had the same problem as me. Some
>> of them are really old (more than 2 years). I found two ways of doing that:
>>    - One way is to implement a instruction algorithm, such as the one
>> described here:
>> http://lists.osgeo.org/pipermail/pgrouting-users/2011-January/000537.html
>>    - The other way is to have an external service to do that, such as,
>> http://techbase.kde.org/Projects/Marble/RoutingInstructions
>> Now, my question is that neither one of the approaches to having
>> navigation directions from a pgRouting route is optimized or well
>> documented.
>> Are there any new alternatives to these two approaches? If not, is there
>> a more developed solution to the route instructions issue (commonly called
>> Driving Directions issue) ?
> Hi Paulo,
> As you have already said, this question came up quite a few times already.
> I think the reason, why there is no out-of-the-box solution yet, is, that
> it is very difficult (probably impossible) to provide this kind of driving
> instructions in a way that it works for any (road) network.
> And beside the variety of data there are also lots of languages.
> If you (or someone else) is able to draft a concept how to produce driving
> directions in a smart way, that it does not depend on a specific dataset or
> language, then such a functionality would be a valuable contribution ...
> which might even attract some funding ;)
> Regards,
> Daniel
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
> pgrouting-dev mailing list
> pgrouting-dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/pgrouting-dev
Paulo Figueiras <paf at uninova.pt <%3Crddc at uninova.pt>>
[image: cid:image002.jpg at 01C8AEC7.2F6E45A0] <http://www.uninova.pt/>
UNINOVA, Centre of Technology and Systems
Campus da Caparica, Quinta da Torre
2829-516 Monte Caparica, PORTUGAL
Phone: (+351) 212948312 | Fax: (+351) 212957786 | Website:
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20131128/0e77f0c4/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20131128/0e77f0c4/attachment-0001.jpg>
More information about the pgrouting-dev mailing list
