[pgrouting-dev] Want to contribute to pgrouting
Vicky Vergara vicky at georepublic.de
Fri Feb 5 20:03:43 PST 2021
Hello Riya,
If you are interested on pgROuting because of GSoC, please read:
https://github.com/pgRouting/pgrouting/wiki/GSoC-Ideas%3A-2021
There will be help meetings that are announced on that page. Starting
tomorrow.
Regards
Vicky
On Thu, Feb 4, 2021 at 7:57 AM Riya Singh <rsingh99mysteryfan at gmail.com>
wrote:
> Thank you for the help, I am going through the workshops and documentation
> of pgRouting.
> The problems which I am facing is related to postgresql database setup.
> In the readme file its mentioned:
> *createdb mydatabase
> psql mydatabase -c "CREATE EXTENSION pgrouting CASCADE"*
> In the documentation http://docs.pgrouting.org/latest/en/pgRouting-installation.html its mentioned:
> createdb routing
> psql routing -c 'CREATE EXTENSION PostGIS'
> psql routing -c 'CREATE EXTENSION pgRouting'
> CREATE EXTENSION postgis;CREATE EXTENSION pgrouting;
>     I am bit confused regarding this. Can you please expalin the steps in
> the order they should be exexcuted.
> On Mon, Feb 1, 2021 at 7:25 AM Daniel Kastl <daniel at georepublic.de> wrote:
>> Hi Riya,
>> Nice to hear you are interested in pgRouting and GSoC!
>> It's hard to guess what you are confused about with the setup, so you had
>> to explain ore in detail.
>> I would also recommend you to do the latest pgRouting workshop:
>> https://workshop.pgrouting.org/
>> Best regards,
>> Daniel
>> On Mon, 1 Feb 2021 at 02:01, Riya Singh <rsingh99mysteryfan at gmail.com>
>> wrote:
>>> Hi everyone,
>>> I am Riya Singh a 3rd year computer science undergraduate and I
>>> would like to contribute to this project as a part of gsoc 2021. I have
>>> read the gsoc 2021 guidelines and also tried setting up the project locally
>>> on my system. I use Ubuntu 20.04 and I have installed postgresql and
>>> postgis and also compiled the project locally. But I am a bit confused
>>> about database setup. CAn someone please guide what instructions to run
>>> because there are multiple instructions mentioned in the wiki and the
>>> documentation page.
>>> pgrouting-dev mailing list
>>> pgrouting-dev at lists.osgeo.org
>>> https://lists.osgeo.org/mailman/listinfo/pgrouting-dev
>> Georepublic UG & Georepublic Japan
>> eMail: daniel.kastl at georepublic.de
>> Web: https://georepublic.info
Georepublic UG (haftungsbeschränkt)
Salzmannstraße 44,
81739 München, Germany
Vicky Vergara
Operations Research
eMail: vicky at georepublic.de
Tel: +49 (089) 4161 7698-1
Fax: +49 (089) 4161 7698-9
Commercial register: Amtsgericht München, HRB 181428
CEO: Daniel Kastl
URL: <http://lists.osgeo.org/pipermail/pgrouting-dev/attachments/20210205/af425940/attachment.html>
More information about the pgrouting-dev mailing list
