[postgis-devel] release status
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Mon Feb 21 06:07:03 PST 2005
Hi strk,
The only other thing to mention would be the compile-time warnings under
Win32 (it appears that the Win32 header files also define a typedef 'byte'
which clashes with the definition used by the parser). Unfortunately I don't
think I'm going to have time to fix this for a while, but I thought I should
mention it in case anyone else can fix it in time for the release.
Kind regards,
Mark.
WebBased Ltd
South West Technology Centre
Tamar Science Park
Plymouth
PL6 8BT
T: +44 (0)1752 791021
F: +44 (0)1752 791023
W: http://www.webbased.co.uk
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of strk at refractions.net
> Sent: 18 February 2005 07:51
> To: postgis-devel at postgis.refractions.net
> Subject: Re: [postgis-devel] release status
> The mapserver connector bug seems to be fixed, the only issue
> left is the spatial_ref_sys entries.
> The reported *bogus* entry was one of Paris ones  (27582).
> We have more then a single entries for Paris, sharing most of
> the parameters that requires correction, so what I don't know
> is wheter all of them are really *wrong* or if different
> PROJ4 versions handle different parameters.
> Frank, can you tell us something about this ?
> Finally we have a minor problem with FLEX and YACC variables
> being somehow overidden by postgresql Makefiles, did anyone
> here ever compiled postgis using different lexical analyzer /
> parser generators ? Should we directly invoke 'flex' and
> 'yacc' instead of using variables ?
> --strk;
