[postgis-devel] Small jdbc2 patch
strk at refractions.net strk at refractions.net
Fri Jan 28 07:57:49 PST 2005
On Fri, Jan 28, 2005 at 04:03:18PM +0100, Markus Schaber wrote:
> Hi, Strk,
> strk at refractions.net schrieb:
> >>BTW, as I got no feedback from users up to now: Did anyone besides strk
> >>and me actually test or use this code? Are we the only PostGIS JDBC
> >>users altogether?
> > Count me out, I'm not a JDBC user at all, just tried to build it ;)
> At least, you ran the provided regression tests successfully :-)
> > BTW: would you review the README before final release ?
> Yes, I'll do so. (It's on the todo list, actually :-) What's the
> schedule for the final release? I think at least those spurious server
> crashes regarding Points should be fixed before.
They should, but so far no "developer" could reproduce them.
I'm trying working with Horst on finding out more.
Beside that, one week of no-bug-reports and 1.0.0 is out
(I hope this won't keep users from testing ;)
> Currently, I'm working on fixing Box3D and Box which turned out to be
> broken in current version. I'll also add a regression test for them.
> BTW, should the latter one be called PGBox2d instead of PGBox? The
> PostgreSQL datatype is named "box2d", but the canonical rep starts with
> "BOX(".
Postgres has a BOX type, so you should probably make postgis one
a BOX2D, to avoid name clashes.
--strk;
> Thanks,
> Markus
> markus schaber | dipl. informatiker
> logi-track ag | rennweg 14-16 | ch 8001 zürich
> phone +41-43-888 62 52 | fax +41-43-888 62 53
> mailto:schabios at logi-track.com | www.logi-track.com
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
