[postgis-devel] PATCH: Fix broken regress_proj test in HEAD
Mark Cave-Ayland mark.cave-ayland at ilande.co.uk
Thu May 10 06:40:18 PDT 2007
Hi everyone,
This patch fixes a bug in regress_proj triggered by this commit:
http://postgis.refractions.net/pipermail/postgis-commits/2007-February/000045.html. Since regress_proj_expected contains the DELETE output from PostgreSQL (which the above commit now removes), the regress_proj test always fails. The solution is to remove the DELETE line from regress_proj_expected as done by the attached patch. If no-one objects, I'll commit this over the weekend.
Kind regards,
Mark.
ILande - Open Source Consultancy
http://www.ilande.co.uk
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20070510/e0fbc248/attachment.bin>
