[postgis-devel] Issue 31 in postgis: Negative distance buffer
codesite-noreply at google.com codesite-noreply at google.com
Thu Jul 17 04:04:21 PDT 2008
Issue 31: Negative distance buffer
Comment #5 by joaofgo:
Seems like a similar problem is already in GEOS trac
 I had some difficulties when trying to find out some information/samples/examples
regarding the use of the XMLTester in GEOS and also regarding the XML
test schema.
However, I was able to assemble some xml files from my test data (used
a simple
script to generate this files based on PostGIS results) and I ran them
through the
XMLTester as suggested for GEOS and also for JTS. The results can be
observed in the
attached files. Seems like there is a high error rate when using
st_buffer (for both
inner and outer rings) and that JTS has got a more conservative error detection
approach (?) compared to GEOS.
  Please check out the syntax for the attached xml files and the
results. I hope that
this tests help to track the problem. Any ideas for results
interpretation? More
testing needed?
	buffer_test.zip  1.3 MB
You received this message because you are listed in the owner
or CC fields of this issue, or because you starred this issue.
You may adjust your issue notification preferences at:
