[postgis-devel] ST_Area, ST_Area2D
Paul Ramsey
pramsey at cleverelephant.ca
Fri Jul 18 08:06:30 PDT 2008
length3d should return a different result for a 3d line than
lenght2d... and we do need both variants, since sometimes you want the
2d legth of a 3d line.
P.
On Fri, Jul 18, 2008 at 7:55 AM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> Paul,
> Ditto for these too? ESRI and IBM just refer to this as ST_Length
> --Docs have ST_Length2D and 3D but no ST_Length
> ST_length2d(geometry)
> Returns the 2-dimensional length of the geometry if it is a
> linestring or multi-linestring.
> Just replace with ST_Length()?
> Both ST_Length() and ST_Length2d() map to -
> LWGEOM_length2d_linestring
> Now ST_Length3D() maps to LWGEOM_length_linestring
> Which on closer tests - gives me the same answer as ST_Length() for a
> 2-d string.
> Is there a reason why we can't just have a single documented
> ST_Length and state it works for both 2D and 3D strings? and in future
> versions just have all 3 map to LWGEOM_length_linestring
> and deprecate the 2D and 3D names?
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
> Ramsey
> Sent: Friday, July 18, 2008 10:35 AM
> To: PostGIS Development Discussion
> Subject: Re: [postgis-devel] ST_Area, ST_Area2D
> Undocument it, and note that it is deliberately undocumented in the
> .sql.in file, so we don't go and re-document it in the future.
> On Fri, Jul 18, 2008 at 5:36 AM, Obe, Regina <robe.dnd at cityofboston.gov>
> wrote:
>> Can I scrap ST_Area2D from docs and just replace with ST_Area? or is
>> ST_Area2D really the preferred name? They both map to
>> LWGEOM_area_polygon, but
>> the docs list the ST_Area2D one which seems a bit more verbose and
>> unconventional.
>> Both IBM and ESRI on quick search just call it ST_Area
>> IBM -
> publib.boulder.ibm.com/infocenter/db2luw/v9/topic/com.ibm.db2.udb.spatia
>> l.doc/rsbp4034.html
>> and Esri
> webhelp.esri.com/arcgisserver/9.3/java/geodatabases/st_area.htm
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended
>> solely for the addressee. If you received this in error, please
>> contact the sender and delete the material from any computer.
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
