[postgis-devel] ST_Area, ST_Area2D
Paul Ramsey
pramsey at cleverelephant.ca
Fri Jul 18 08:07:14 PDT 2008
To wit:
netezza=# select length3d('LINESTRING(0 0 0,1 1 1)');
length3d
1.73205080756888
(1 row)
netezza=# select length2d('LINESTRING(0 0 0,1 1 1)');
length2d
1.4142135623731
(1 row)
On Fri, Jul 18, 2008 at 8:06 AM, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> length3d should return a different result for a 3d line than
> lenght2d... and we do need both variants, since sometimes you want the
> 2d legth of a 3d line.
> P.
> On Fri, Jul 18, 2008 at 7:55 AM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
>> Paul,
>> Ditto for these too? ESRI and IBM just refer to this as ST_Length
>> --Docs have ST_Length2D and 3D but no ST_Length
>> ST_length2d(geometry)
>> Returns the 2-dimensional length of the geometry if it is a
>> linestring or multi-linestring.
>> Just replace with ST_Length()?
>> Both ST_Length() and ST_Length2d() map to -
>> LWGEOM_length2d_linestring
>> Now ST_Length3D() maps to LWGEOM_length_linestring
>> Which on closer tests - gives me the same answer as ST_Length() for a
>> 2-d string.
>> Is there a reason why we can't just have a single documented
>> ST_Length and state it works for both 2D and 3D strings? and in future
>> versions just have all 3 map to LWGEOM_length_linestring
>> and deprecate the 2D and 3D names?
>> Thanks,
>> Regina
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net
>> [mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
>> Ramsey
>> Sent: Friday, July 18, 2008 10:35 AM
>> To: PostGIS Development Discussion
>> Subject: Re: [postgis-devel] ST_Area, ST_Area2D
>> Undocument it, and note that it is deliberately undocumented in the
>> .sql.in file, so we don't go and re-document it in the future.
>> On Fri, Jul 18, 2008 at 5:36 AM, Obe, Regina <robe.dnd at cityofboston.gov>
>> wrote:
>>> Can I scrap ST_Area2D from docs and just replace with ST_Area? or is
>>> ST_Area2D really the preferred name? They both map to
>>> LWGEOM_area_polygon, but
>>> the docs list the ST_Area2D one which seems a bit more verbose and
>>> unconventional.
>>> Both IBM and ESRI on quick search just call it ST_Area
>>> IBM -
>> publib.boulder.ibm.com/infocenter/db2luw/v9/topic/com.ibm.db2.udb.spatia
>>> l.doc/rsbp4034.html
>>> and Esri
>> webhelp.esri.com/arcgisserver/9.3/java/geodatabases/st_area.htm
>>> The substance of this message, including any attachments, may be
>>> confidential, legally privileged and/or exempt from disclosure
>>> pursuant to Massachusetts law. It is intended
>>> solely for the addressee. If you received this in error, please
>>> contact the sender and delete the material from any computer.
>>> postgis-devel mailing list
>>> postgis-devel at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
