[postgis-devel] Status of shp2pgsql-core/shp2pgsql?
Paul Ramsey pramsey at opengeo.org
Sun Apr 12 09:59:48 PDT 2009
Just guts. I didn't have the guts to ditch the old one when I put in
the new ones. Mostly because the workflow of the new ones is slightly
more complicated, to allow for the GUI to keep it's display thread in
place as work runs.
I can flip over to the new core and re-name shp2pgsql-cli to shp2pgsql.
P
On Fri, Apr 10, 2009 at 1:53 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Paul,
> What's the current status of these two files? The reason I ask is that for
> the escaping changes I just committed to SVN trunk, I had to make the commit
> in both of the above files which is not conducive to long-term maintenance
> I guess it comes down to whether we are officially supporting the GUI, and
> if so, what the reason preventing the shared shp2pgsql-core from being used
> by both the command line and GUI versions?
> ATB,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect
> PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
