[postgis-devel] Status of shp2pgsql-core/shp2pgsql?
Paragon Corporation lr at pcorp.us
Sun Apr 12 11:00:44 PDT 2009
While you guys are at it can you refix what you had fixed that got broken by
Mark's change unless we are okay with popel getting these warnings sometime.
More importantly I think something else got broken by Marks change but not
sure if its just the test shape file I was using, but it worked before Mark
made his change.  I attached it to the ticket.
On another note -- do we have trac bug reports going to the postgis-dev
mailing list.  I don't seem to be seeing them coming thru on the list though
I do get them personally when I post them.
Thanks,
Regina
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Sunday, April 12, 2009 1:00 PM
To: PostGIS Development Discussion
Subject: Re: [postgis-devel] Status of shp2pgsql-core/shp2pgsql?
Just guts. I didn't have the guts to ditch the old one when I put in the new
ones. Mostly because the workflow of the new ones is slightly more
complicated, to allow for the GUI to keep it's display thread in place as
work runs.
I can flip over to the new core and re-name shp2pgsql-cli to shp2pgsql.
P
On Fri, Apr 10, 2009 at 1:53 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> Paul,
> What's the current status of these two files? The reason I ask is that
> for the escaping changes I just committed to SVN trunk, I had to make
> the commit in both of the above files which is not conducive to
> long-term maintenance :(
> I guess it comes down to whether we are officially supporting the GUI,
> and if so, what the reason preventing the shared shp2pgsql-core from
> being used by both the command line and GUI versions?
> ATB,
> Mark.
> Mark Cave-Ayland - Senior Technical Architect PostgreSQL - PostGIS
> Sirius Corporation plc - control through freedom
> http://www.siriusit.co.uk
> t: +44 870 608 0063
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
