[postgis-devel] License
Obe, Regina robe.dnd at cityofboston.gov
Wed Feb 4 19:57:36 PST 2009
Just to clarify my concern.  someone correct me if I am wrong
Main issue is I think PostGIS is still too young and forcing it to be in line with PostgreSQL releases would hamper its pace significantly.
The way I see it, it would tie our GEOS and PostGIS version to specific PostgreSQL versions which would be really bad at this point.
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net on behalf of Obe, Regina
Sent: Wed 2/4/2009 10:06 PM
To: PostGIS Development Discussion
Subject: RE: [postgis-devel] License
> There are downsides for users by having the PostGIS versions seperate
> from the PostgreSQL ones..  Primairly, having to deal with the whole
> upgrade process when going from PostgreSQL major versions.  It's pretty
> much an ugly mess, if you ask me.  Having PostGIS included in core would
> simplify that process immensly..
>	Stephen
I'm not convinced it would.  You still need to do a dump reload and functions change.
Even with being baked in, I don't see this being fixed since the functions and even the underlying structure
changes.
I think we just need to do a better job of making PostGIS upgrades less painful apart from PostgreSQL.
Plus some people may need to run 1.3 and some may opt to go 1.4, this would no longer be possible is my thinking.
I personally would have a problem with some of my bigger installs.
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20090204/7d06333b/attachment.html>
