[postgis-devel] [PostGIS] #78: CheckAuth - doesn't check if trigger exists before trying to create it also why return 0
PostGIS trac at osgeo.org
Fri Nov 13 17:18:25 PST 2009
why return 0
  Reporter:  robe     |       Owner:  robe
      Type:  defect   |      Status:  closed
  Priority:  low      |   Milestone:  postgis 1.4.1
 Component:  postgis  |     Version:
Resolution:  wontfix  |    Keywords:
Changes (by pramsey):
  * status:  assigned => closed
  * resolution:  accepted => wontfix
Comment:
 Nobody cares, apparently.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/78#comment:5>
