[postgis-devel] postgis-1.5.sql
Paragon Corporation lr at pcorp.us
Mon Nov 16 14:31:45 PST 2009
To add I think we have enough uninstall ..sql this and that that having to
label each accordingly would be a pain, and when you want to install -- just
delete the whole folder
So the way the windows install current structure is
contrib/postgis (to store the shared proj etc.)
contrib/postgis-1.4
contrib/postgis-1.5
I actually wanted to do the same thing with the template_postgis (so as not
to overwrite  for people who one to run separate versions on the same
postgresql service)
-----Original Message-----
From: postgis-devel-bounces at postgis.refractions.net
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paragon
Corporation
Sent: Monday, November 16, 2009 5:28 PM
To: 'PostGIS Development Discussion'
Subject: Re: [postgis-devel] postgis-1.5.sql
I personally like the idea of numbering the whole contrib/postgis-1.5
That is what I have done with the Windows installs.  Its easier to manage I
think, because each version is in its own folder so you don't have to guess
what goes with what.  Like naming uninstall etc. and changing the script
each version
[mailto:postgis-devel-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Monday, November 16, 2009 5:18 PM
To: PostGIS Development Discussion
Well, problem solved then, if I'm the only one who ever objected (and at a
different circumstance at that). I guess I don't have the courage of my
convictions.
P.
On Mon, Nov 16, 2009 at 2:12 PM, Chris Hodgson <chodgson at refractions.net>
wrote:
> Paul, you bring this question up so often it makes me wonder if there
> really is a reason...
> http://postgis.refractions.net/pipermail/postgis-devel/2009-August/006
> 599.html
> It all pints back to:
> http://trac.osgeo.org/postgis/ticket/94
> Where it seems the argument against numbering the .sql was that you'd
> have to also number the .so, which you didn't want to do because it
> complicated the update process.
> Chris
> Paul Ramsey wrote:
>> What do we think about numbering the SQL file? I think it seems wise,
>> is there a reason to not do it?
>> P
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
