[postgis-devel] (no subject)
Paul Ramsey pramsey at cleverelephant.ca
Sun Apr 10 07:03:45 PDT 2011
Problem is likely with the bytea encoding change in 9.0 make sure you also upgrade your pgsql jar.
On 2011-04-08, at 6:40 AM, RANDYHORNER <randy.horner at nisc.coop> wrote:
> Thanks for the response.   I wanted to keep it short and I had hoped the
> answer was obvious and the java code has a dumb error on my part.  I had not
> worked on this for some time so I'm not exactly sure what has changed.
> postgis_1.3.3.jar to postgis-1.5.0.jar but backing up did not help.  I do
> not believe the data changed.  I believe we've also upgraded to postgresql
> 9.0.
> "POSTGIS="1.5.2" GEOS="3.2.2-CAPI-1.6.2" PROJ="Rel. 4.6.1, 21 August 2008"
> View this message in context: http://old.nabble.com/%28no-subject%29-tp31341827p31351834.html
> Sent from the PostGIS - Dev mailing list archive at Nabble.com.
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
