[postgis-devel] [PostGIS] #925: [raster] ST_Transform
PostGIS trac at osgeo.org
Tue Jun 14 12:57:40 PDT 2011
 Reporter:  dustymugs       |       Owner:  dustymugs
     Type:  task            |      Status:  assigned
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:  history         |
Comment(by dustymugs):
 Pierre and Regina,
 Have either of you been able to get the regression tests to run
 successfully?  I did make some changes to the regression tests due to the
 different answers possible if using different versions of GDAL.
 If neither of you have problems, can one of you close this ticket?
 Thanks!
Ticket URL: <http://trac.osgeo.org/postgis/ticket/925#comment:55>
