[postgis-devel] Win32 Adventures
Mike Toews mwtoews at gmail.com
Mon Feb 27 00:42:52 PST 2012
On 26 February 2012 10:36, Paul Ramsey <pramsey at cleverelephant.ca> wrote:
> SVN is curiously not part of mingw-get, I guess it has too many
> dependencies, so I used the commandline build from sliksvn.
If you install a recent (1.7.x) version of TortoiseSVN, you have the
option to install the shell commands to your PATH. This is off by
default with the installer. I've tested it out with the MinGW Shell,
and all the svn commands work as they should.
$ which svn
/c/Program Files/TortoiseSVN/bin/svn.exe
-Mike
