[postgis-devel] Docs broken for other languages
George Silva georger.silva at gmail.com
Mon Jan 30 08:39:19 PST 2017
Regarding the README, I'll separate sometime for that.
Regarding the weblate/pootle thing: I need to confirm with my associates if
we still can provide the server. The ideal thing is to talk to osgeo to see
if they have a spare webserver for that. There are many projects that could
use the same resource instead of using transifex. I'll take that to the
osgeo list. If they provide the server, we can customize the auth, so it
will look at osgeo's LDAP and provide some maintenance.
Now, for what I can see, the resources are pointing to svn-trunk.
@Regina, I took a look at the generated docs, and it looks like they are
built from another branch, not svn-trunk. I can tell that because pt-br has
the highest number of strings translated and a number of them are not
translated.
Perhaps you generated the docs from the master? How are PostGIS branches
organized these days btw?
Thanks!
On Mon, Jan 30, 2017 at 2:31 PM, Sandro Santilli <strk at kbt.io> wrote:
> On Mon, Jan 30, 2017 at 08:31:39AM -0200, George Silva wrote:
> > Thanks Regina.
> > @strk: for what I know the docs are only updated on transifex when the
> > changes hit the svn-trunk branch, correct?
> George: you know Transifex better than I do, so please find out and
> let us know :) --- note I'm still happy to switch from transifex
> to weblate if you're up for championing that
> (https://weblate.org/en/hosting/)
> > Is there anything we can help in these proceedings?
> Maybe improve doc/po/README with the recommended workflow
> for updates, in both branches and trunk ?
> --strk;
> postgis-devel mailing list
> postgis-devel at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/postgis-devel
George R. C. Silva
Sigma Geosistemas LTDA
http://www.sigmageosistemas.com.br/
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20170130/72a76221/attachment.html>
