[postgis-tickets] [SCM] postgis.net branch hugo updated. c71c25760f8a27daac9743e4af5d930e7de166fd
Sun Feb 27 19:28:31 PST 2022
the project "postgis.net".
The branch, hugo has been updated
       via  c71c25760f8a27daac9743e4af5d930e7de166fd (commit)
      from  630e41a19bff5bad1172847f65105949e529c3c6 (commit)
revisions in full, below.
commit c71c25760f8a27daac9743e4af5d930e7de166fd
Author: Regina Obe <lr at pcorp.us>
Date:   Sun Feb 27 22:28:18 2022 -0500
    More article conversions
diff --git a/content/pages/windows_downloads.md b/content/pages/windows_downloads.md
index 9a45803..aafbf29 100644
--- a/content/pages/windows_downloads.md
+++ b/content/pages/windows_downloads.md
@@ -79,7 +79,7 @@ Setup is detailed in [Starting PostgreSQL in windows without install](http://www
 PostGIS is an optional extension that must be enabled in EVERY database you want to use it in.
-{% geshi 'sql' %}
+```postgres
 CREATE EXTENSION postgis;
 -- in PostGIS 3, postgis_raster is a separate extension from postgis
 -- so do this in addition if you are experimenting PostGIS 3+
@@ -90,14 +90,14 @@ CREATE EXTENSION address_standardizer;
 CREATE EXTENSION fuzzystrmatch;
 CREATE EXTENSION postgis_topology;
 CREATE EXTENSION postgis_tiger_geocoder;
-{% endgeshi %}
 If you want to use pgrouting, download the respective one for your PostgreSQL/
-{% geshi 'sql' %}
+```postgres
 CREATE EXTENSION pgrouting;
-{% endgeshi %}
 For loading OpenStreetMap data (OSM) into pgrouting format, you can use osm2po or [osm2pgrouting][10].
 Windows binaries for osm2pgrouting can be found in the `extras` folder of each version. Refer to instructions in the zip.
diff --git a/content/post/2019/03-11_postgis-patches.md b/content/post/2019/03-11_postgis-patches.md
new file mode 100644
index 0000000..b303e41
--- /dev/null
+++ b/content/post/2019/03-11_postgis-patches.md
@@ -0,0 +1,77 @@
+title: PostGIS 2.5.2, 2.4.7, 2.3.9 Released
+layout: post
+category: news
+tags: [release,2.5,2.4,2.3,2.5.2,2.4.7,2.3.9]
+author: Regina Obe
+date: "2019-03-11"
+thumbnail: postgis.png
+The PostGIS development team is pleased to provide
+bug fix 2.5.2, 2.4.7, and 2.3.9 for the 2.5, 2.4, and 2.3 stable branches.
+These are the first versions to be able to compile against [Proj 6.0.0](https://proj4.org/download.html),
+You must upgrade to these if you are using Proj 6.
+<!-- pagebreak -->
+**2.5.2**
+This release supports PostgreSQL 9.3-11
+(will compile against PostgreSQL 12, but not pass tests. Use only for pg_upgrade.
+You are encouraged to use the PostGIS 3.0 unreleased branch with PostgreSQL 12
+, which has features specifically designed to take advantage of features new in PostgreSQL 12).
+* [source download]({{< loc "postgis.release_source">}}/postgis-2.5.2.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/2.5.2/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-2.5.2.pdf) [de]({{< loc "postgis.release_docs">}}/postgis-2.5.2-de.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-2.5.2.tar.gz)
+* html online [en]({{< loc "site.root">}}docs/manual-2.5) [de]({{< loc "site.root">}}docs/manual-2.5/postgis-de.html) [ja]({{< loc "site.root">}}docs/manual-2.5/postgis-ja.html)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-2.5.2.epub)
+* [Changelog](https://svn.osgeo.org/postgis/tags/2.5.2/ChangeLog)
+**2.4.7**
+This release supports PostgreSQL 9.3-10.
+* [source download]({{< loc "postgis.release_source">}}/postgis-2.4.7.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/2.4.7/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-2.4.7.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-2.4.7.tar.gz)
+* html online [en]({{< loc "site.root">}}docs/manual-2.4)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-2.4.7.epub)
+* [Changelog](https://svn.osgeo.org/postgis/tags/2.4.7/ChangeLog)
+**2.3.9**
+This release supports PostgreSQL 9.2-10.
+* [source download]({{< loc "postgis.release_source">}}/postgis-2.3.9.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/2.3.9/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-2.3.9.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-2.3.9.tar.gz)
+* html online [en]({{< loc "site.root">}}docs/manual-2.3)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-2.3.9.epub)
+* [Changelog](https://svn.osgeo.org/postgis/tags/2.3.9/ChangeLog)
+View all [closed tickets for 2.5.2, 2.4.7, 2.3.9][1].
+After installing the binaries or after running pg_upgrade, make sure to do:
+```postgres
+ALTER EXTENSION postgis UPDATE;
+-- if you use the other extensions packaged with postgis
+-- make sure to upgrade those as well
+```postgres
+ALTER EXTENSION postgis_sfcgal UPDATE;
+ALTER EXTENSION postgis_topology UPDATE;
+ALTER EXTENSION postgis_tiger_geocoder UPDATE;
+If you use legacy.sql or legacy_minimal.sql,
+make sure to rerun the version packaged with these releases.
+[1]: https://trac.osgeo.org/postgis/query?status=closed&resolution=fixed&milestone=PostGIS+2.3.9&milestone=PostGIS+2.4.7&milestone=PostGIS+2.5.2&col=id&col=summary&col=milestone&col=status&col=type&col=priority&col=component&order=priority
diff --git a/content/post/2019/05-26_postgis-3.0.0alpha1.md b/content/post/2019/05-26_postgis-3.0.0alpha1.md
index 0000000..51ab341
--- /dev/null
+++ b/content/post/2019/05-26_postgis-3.0.0alpha1.md
@@ -0,0 +1,57 @@
+title: PostGIS 3.0.0alpha1
+layout: post
+category: news
+tags: [release,3.0, 3.0.0alpha1]
+author: Regina Obe
+date: "2019-05-26"
+The PostGIS development team is pleased to release PostGIS 3.0.0alpha1.
+This release works with PostgreSQL 9.5-12beta1  and GEOS >= 3.6
+Best served with PostgreSQL 12beta1.
+<!-- pagebreak -->
+**3.0.0alpha1**
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.0.0alpha1.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.0.0alpha1/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.0.0alpha1.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.0.0alpha1.tar.gz)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.0.0alpha1.epub)
+* [Changelog](https://svn.osgeo.org/postgis/tags/3.0.0alpha1/ChangeLog)
+View all [closed tickets for 3.0.0][1].
+Note that a major change in 3.0 is that the raster functionality has been broken out as a separate extension.
+If you are upgrading from a previous edition, do the following:
+```postgres
+-- this next step repackages raster in its own extension
+-- and upgrades all your other related postgis extension
+SELECT PostGIS_Extensions_Upgrade();
+--if you don't use raster, you can do
+DROP EXTENSION postgis_raster;
+-- New users
+```postgres
+CREATE EXTENSION postgis;
+CREATE EXTENSION postgis_raster;
+CREATE EXTENSION postgis_topology;
+CREATE EXTENSION postgis_tiger_geocoder;
+[1]: https://trac.osgeo.org/postgis/query?status=closed&resolution=fixed&milestone=PostGIS+3.0.0&col=id&col=summary&col=milestone&col=status&col=type&col=priority&col=component&order=priority
diff --git a/content/post/2019/06-02_postgis-3.0.0alpha2.md b/content/post/2019/06-02_postgis-3.0.0alpha2.md
index 0000000..03155aa
--- /dev/null
+++ b/content/post/2019/06-02_postgis-3.0.0alpha2.md
@@ -0,0 +1,68 @@
+title: PostGIS 3.0.0alpha2
+layout: post
+category: news
+tags: [release,3.0, 3.0.0alpha2]
+author: Regina Obe
+date: "2019-06-02"
+The PostGIS development team is pleased to release PostGIS 3.0.0alpha2.
+<!-- pagebreak -->
+**3.0.0alpha2**
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.0.0alpha2.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.0.0alpha2/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.0.0alpha2.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.0.0alpha2.tar.gz)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.0.0alpha2.epub)
+* [Changelog](https://svn.osgeo.org/postgis/tags/3.0.0alpha2/ChangeLog)
+Changes since PostGIS 3.0.0alpha1 release are as follows:
+* 4404, [Fix selectivity issue with support functions (Paul Ramsey)](http://blog.cleverelephant.ca/2019/05/parallel-postgis-4.html)
+* 4311, Make wagyu the default option to validate polygons.
+    This option requires a C++11 compiler and will use CXXFLAGS (not CFLAGS).
+    It only enabled if built with MVT support (protobuf) and should speed up mvt tile generations
+    Add `--without-wagyu` to disable this option and keep the behaviour
+    from 2.5 (Raúl Marín)
+* 4198, Add [ST_ConstrainedDelaunayTriangles](/docs/manual-dev/ST_ConstrainedDelaunayTriangles.html) SFCGAL function (Darafei
+    Praliaskouski)
+```postgres
+-- New users
+```postgres
diff --git a/content/post/2019/07-01_postgis-3.0.0alpha3.md b/content/post/2019/07-01_postgis-3.0.0alpha3.md
index 0000000..9aadda4
--- /dev/null
+++ b/content/post/2019/07-01_postgis-3.0.0alpha3.md
@@ -0,0 +1,76 @@
+title: PostGIS 3.0.0alpha3
+layout: post
+category: news
+tags: [release,3.0,3.0.0alpha3]
+author: Regina Obe
+date: "2019-07-01"
+The PostGIS development team is pleased to release PostGIS 3.0.0alpha3.
+This release works with PostgreSQL 9.5-12beta2  and GEOS >= 3.6
+Best served with [PostgreSQL 12beta2](https://www.postgresql.org/developer/beta/).
+<!-- pagebreak -->
+**3.0.0alpha3**
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.0.0alpha3.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.0.0alpha3/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.0.0alpha3.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.0.0alpha3.tar.gz)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.0.0alpha3.epub)
+* [Changelog](https://svn.osgeo.org/postgis/tags/3.0.0alpha3/ChangeLog)
+Main changes since PostGIS 3.0.0alpha2 release are as follows:
+* 4438, Update serialization to support extended flags area (Paul Ramsey)
+* 3437, Speed up ST_Intersects with Points (Raúl Marín)
+* 4352, Use CREATE OR REPLACE AGGREGATE for PG12+ (Raúl Marín)
+* 4441, Make GiST penalty friendly to multi-column indexes and build single-column
+         ones faster. (Darafei Praliaskouski)
+* 4372, PROJ6: Speed improvements (Raúl Marín)
+* 4414, Include version number in address_standardizer lib (Raúl Marín)
+* 4334, Fix upgrade issues related to renamed parameters (Raúl Marín)
+* 4388, AddRasterConstraints: Ignore NULLs when generating constraints (Raúl Marín)
+* 4327, Avoid pfree'ing the result of getenv (Raúl Marín)
+* 4406, Throw on invalid characters when decoding geohash (Raúl Marín)
+* 4429, Avoid resource leaks with PROJ6 (Raúl Marín)
+* 4443, Fix wagyu configure dropping CPPFLAGS (Raúl Marín)
+* 4440, Type lookups in FDW fail (Paul Ramsey)
+* 4442, raster2pgsql now skips NODATA tiles. Use -k option if you still want
+         them in database for some reason. (Darafei Praliaskouski)
+```postgres
+-- New users
+```postgres
diff --git a/content/post/2019/08-11_postgis-patches.md b/content/post/2019/08-11_postgis-patches.md
index 0000000..7fc9275
--- /dev/null
+++ b/content/post/2019/08-11_postgis-patches.md
@@ -0,0 +1,87 @@
+title: PostGIS 3.0.0alpha4, 2.5.3, 2.4.8, 2.3.10 Released
+layout: post
+category: news
+tags: [release,3.0, 2.5,2.4,2.3,2.5.3,2.4.8,2.3.10]
+author: Regina Obe
+date: "2019-08-11"
+enhancements/features 3.0.0alpha4 for 3.0 feature major branch
+bug fix 2.5.3, 2.4.8, and 2.3.10 for the 2.5, 2.4, and 2.3 stable branches.
+<!-- pagebreak -->
+**3.0.0alpha4**
+This release works with PostgreSQL 9.5-12beta3  and GEOS >= 3.6
+Best served with [PostgreSQL 12beta3](https://www.postgresql.org/developer/beta/).
+Designed to take advantage of features in PostgreSQL 12 and Proj 6
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.0.0alpha4.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.0.0alpha4/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.0.0alpha4.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.0.0alpha4.tar.gz)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.0.0alpha4.epub)
+* [Changelog](https://svn.osgeo.org/postgis/tags/3.0.0alpha4/ChangeLog)
+**2.5.3**
+This release supports PostgreSQL 9.3-12
+, which has features specifically designed to take advantage of features new in PostgreSQL 12.
+* [source download]({{< loc "postgis.release_source">}}/postgis-2.5.3.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/2.5.3/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-2.5.3.pdf) [de]({{< loc "postgis.release_docs">}}/postgis-2.5.3-de.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-2.5.3.tar.gz)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-2.5.3.epub)
+* [Changelog](https://svn.osgeo.org/postgis/tags/2.5.3/ChangeLog)
+**2.4.8**
+* [source download]({{< loc "postgis.release_source">}}/postgis-2.4.8.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/2.4.8/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-2.4.8.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-2.4.8.tar.gz)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-2.4.8.epub)
+* [Changelog](https://svn.osgeo.org/postgis/tags/2.4.8/ChangeLog)
+**2.3.10**
+* [source download]({{< loc "postgis.release_source">}}/postgis-2.3.10.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/2.3.10/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-2.3.10.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-2.3.10.tar.gz)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-2.3.10.epub)
+* [Changelog](https://svn.osgeo.org/postgis/tags/2.3.10/ChangeLog)
+View all [closed tickets for 3.0.0, 2.5.3, 2.4.8, 2.3.10][1].
+```postgres
+```postgres
+[1]: https://trac.osgeo.org/postgis/query?status=closed&resolution=fixed&milestone=PostGIS+2.3.10&milestone=PostGIS+2.4.8&milestone=PostGIS+2.5.3&milestone=PostGIS+3.0.0&col=id&col=summary&col=milestone&col=status&col=type&col=priority&col=component&order=priority
diff --git a/content/post/2019/09-28_postgis-3.0.0beta1.md b/content/post/2019/09-28_postgis-3.0.0beta1.md
index 0000000..0415845
--- /dev/null
+++ b/content/post/2019/09-28_postgis-3.0.0beta1.md
@@ -0,0 +1,75 @@
+title: PostGIS 3.0.0beta1
+layout: post
+category: news
+tags: [release,3.0,3.0.0beta1]
+author: Regina Obe
+date: "2019-09-28"
+The PostGIS development team is pleased to release PostGIS 3.0.0beta1.
+This release works with PostgreSQL 9.5-12RC1  and GEOS >= 3.6
+Best served with [PostgreSQL 12RC1](https://www.postgresql.org/developer/beta/)
+and [GEOS 3.8.0beta1](https://lists.osgeo.org/pipermail/geos-devel/2019-September/009267.html)
+both of which came out in the past couple of days.
+<!-- pagebreak -->
+**3.0.0beta1**
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.0.0beta1.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.0.0beta1/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.0.0beta1.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.0.0beta1.tar.gz)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.0.0beta1.epub)
+* [Changelog](https://svn.osgeo.org/postgis/tags/3.0.0beta1/ChangeLog)
+Main changes since PostGIS 3.0.0alpha4 release are as follows:
+* #4492, Fix ST_Simplify ignoring the value of the 3rd parameter (Raúl Marín)
+* #4494, Fix ST_Simplify output having an outdated bbox (Raúl Marín)
+* #4493, Fix ST_RemoveRepeatedPoints output having an outdated bbox (Raúl Marín)
+* #4495, Fix ST_SnapToGrid output having an outdated bbox (Raúl Marín)
+* #4496, Make ST_Simplify(TRIANGLE) collapse if requested (Raúl Marín)
+* #4501, Allow `postgis_tiger_geocoder` to be installable by non-super users (Regina Obe)
+* #4503, Speed up the calculation of cartesian bbox (Raúl Marín)
+* #4504, shp2pgsql -D not working with schema qualified tables (Regina Obe)
+* #4505, Speed up conversion of geometries to/from GEOS (Dan Baston)
+* #4507, Use GEOSMakeValid and GEOSBuildArea for GEOS 3.8+ (Dan Baston)
+* #4491, Speed up ST_RemoveRepeatedPoints (Raúl Marín)
+* #4509, Update geocoder for tiger 2019 (Regina Obe)
+* #4338, tiger geocoder Census block level data (tabblock table) not loading (Regina Obe)
+```postgres
+-* this next step repackages raster in its own extension
+-* and upgrades all your other related postgis extension
+-* New users
+```postgres
diff --git a/content/post/2019/10-08_postgis-3.0.0rc1.md b/content/post/2019/10-08_postgis-3.0.0rc1.md
index 0000000..2572739
--- /dev/null
+++ b/content/post/2019/10-08_postgis-3.0.0rc1.md
@@ -0,0 +1,69 @@
+title: PostGIS 3.0.0rc1
+layout: post
+category: news
+tags: [release,3.0,3.0.0rc1]
+author: Regina Obe
+date: "2019-10-08"
+The PostGIS development team is pleased to release PostGIS 3.0.0rc1.
+This release works with PostgreSQL 9.5-12  and GEOS >= 3.6
+Best served with [PostgreSQL 12](https://www.postgresql.org/about/news/1976/)
+, [GEOS 3.8.0rc2](https://lists.osgeo.org/pipermail/geos-devel/2019-October/009288.html)
+and [pgRouting 3.0.0-alpha](https://github.com/pgRouting/pgrouting/releases/tag/v3.0.0-alpha).
+<!-- pagebreak -->
+**3.0.0rc1**
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.0.0rc1.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.0.0rc1/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.0.0rc1.pdf) [de]({{< loc "postgis.release_docs">}}/postgis-3.0.0rc1-de.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.0.0rc1.tar.gz)
+* html online [en]({{< loc "site.root">}}docs/manual-dev), [de]({{< loc "site.root">}}docs/manual-dev/postgis-de.html), [ko_KR]({{< loc "site.root">}}docs/manual-dev/postgis-ko_KR.html), [ja]({{< loc "site.root">}}docs/manual-dev/postgis-ja.html)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.0.0rc1.epub)
+* [Changelog](https://svn.osgeo.org/postgis/tags/3.0.0rc1/ChangeLog)
+Main changes since PostGIS 3.0.0beta1 release are as follows:
+* #4519, Fix getSRIDbySRS crash (Raúl Marín)
+* #4520, Use a clean environment when detecting C++ libraries (Raúl Marín)
+* Restore `ST_Union` aggregate signature so drop agg not required and re-work
+  performance/size enhancement to continue to avoid
+  using Array type during `ST_Union`, hopefully
+  avoiding Array size limitations. (Paul Ramsey)
+```postgres
+-* New users
+```postgres
diff --git a/content/post/2019/10-13_postgis-3.0.0rc2.md b/content/post/2019/10-13_postgis-3.0.0rc2.md
index 0000000..e1d686c
--- /dev/null
+++ b/content/post/2019/10-13_postgis-3.0.0rc2.md
@@ -0,0 +1,69 @@
+title: PostGIS 3.0.0rc2
+layout: post
+category: news
+tags: [release,3.0,3.0.0rc2]
+author: Regina Obe
+date: "2019-10-13"
+The PostGIS development team is pleased to release PostGIS 3.0.0rc2.
+This will be the final RC before release.
+, [GEOS 3.8.0](https://lists.osgeo.org/pipermail/geos-devel/2019-October/009342.html)
+<!-- pagebreak -->
+**3.0.0rc2**
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.0.0rc2.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.0.0rc2/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.0.0rc2.pdf) [de]({{< loc "postgis.release_docs">}}/postgis-3.0.0rc2-de.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.0.0rc2.tar.gz)
+* html online [en]({{< loc "site.root">}}docs/manual-3.0), [de]({{< loc "site.root">}}docs/manual-3.0/postgis-de.html), [ko_KR]({{< loc "site.root">}}docs/manual-3.0/postgis-ko_KR.html), [ja]({{< loc "site.root">}}docs/manual-3.0/postgis-ja.html)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.0.0rc2.epub)
+* [Changelog](https://svn.osgeo.org/postgis/tags/3.0.0rc2/ChangeLog)
+Main changes since PostGIS 3.0.0rc1 release are as follows:
+* 4534, Fix leak in lwcurvepoly_from_wkb_state (Raúl Marín)
+* 4536, Fix leak in lwcollection_from_wkb_state (Raúl Marín)
+* 4537, Fix leak in WKT collection parser (Raúl Marín)
+* 4535, WKB: Avoid buffer overflow (Raúl Marín)
+```postgres
+-* New users
+```postgres
diff --git a/content/post/2019/10-20_postgis-3.0.0.md b/content/post/2019/10-20_postgis-3.0.0.md
index 0000000..03ffe80
--- /dev/null
+++ b/content/post/2019/10-20_postgis-3.0.0.md
@@ -0,0 +1,200 @@
+layout: post
+category: news
+tags: [release,3.0, 3.0.0]
+author: Regina Obe
+date: "2019-10-20"
+The PostGIS development team is pleased to release PostGIS 3.0.0.
+This release works with PostgreSQL 9.5-12  and GEOS >= 3.6.
+If you are using postgis_sfcgal extension, you need to compile against SFCGAL 1.3.1 or higher.
+and [pgRouting 3.0.0-beta](https://github.com/pgRouting/pgrouting/releases/tag/v3.0.0-beta).
+<!-- pagebreak -->
+**3.0.0**
+* [source download]({{< loc "postgis.release_source">}}/postgis-3.0.0.tar.gz)
+* [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.0.0/NEWS)
+* PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.0.0.pdf) [de]({{< loc "postgis.release_docs">}}/postgis-3.0.0-de.pdf)
+* [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.0.0.tar.gz)
+* [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.0.0.epub)
+* [Changelog](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.0.0/ChangeLog)
+-- Upgrading
+```postgres
+-- and upgrades all your other related postgis extensions
+-- if you don't use raster, you can do below
+-- after the upgrade step
+-- Fresh install
+```postgres
+-- installs geometry and geography support
+-- install these if you need them
+-- 3d and advanced processing
+CREATE EXTENSION postgis_sfcgal;
+-- street address normalization
+CREATE EXTENSION address_standardizer;
+-- geocoder/reverse_geocoder for US census data
+CREATE EXTENSION postgis_tiger_geocoder CASCADE;
+**Key Breaking Changes**
+* 3888, Raster support now in a separate extension - postgis_raster
+         (Sandro Santilli)
+* 3807, Extension library files no longer include the minor version.
+         If you need the old behavior,
+         use the new configure switch `--with-library-minor-version`.
+         This change is intended to smooth future pg_upgrade since lib file names
+         won't change between 3.0, 3.1, 3.* releases (Regina Obe)
+* 4230, ND box operators (overlaps, contains, within, equals) now don't look on
+         dimensions that aren't present in both operands.
+         Please REINDEX your ND indexes after upgrade. (Darafei Praliaskouski)
+* 4433, 32-bit hash fix (requires reindexing hash(geometry) indexes) (Raúl Marín)
+* 3383, Sorting now uses Hilbert curve and Postgres Abbreviated Compare.
+        You need to REINDEX your btree indexes if you had them.
+        (Darafei Praliaskouski)
+**New Features**
+* 2902, postgis_geos_noop (Sandro Santilli)
+* 4128, ST_AsMVT support for Feature ID (Stepan Kuzmin)
+* 4230, SP-GiST and GiST support for ND box operators overlaps, contains,
+         within, equals (Esteban Zimányi and Arthur Lesuisse from Université
+         Libre de Bruxelles (ULB), Darafei Praliaskouski)
+* 4171, ST_3DLineInterpolatePoint (Julien Cabieces, Vincent Mora)
+* 4311, Introduce WAGYU to validate MVT polygons. This option requires a C++11
+         compiler and will use CXXFLAGS (not CFLAGS). Add `--without-wagyu`
+         to disable this option and keep the behaviour from 2.5 (Raúl Marín)
+* 1833, ST_AsGeoJSON(row) generates full GeoJSON Features (Joe Conway)
+* 3687, Casts json(geometry) and jsonb(geometry) for implicit GeoJSON
+         generation (Paul Ramsey)
+* 4198, Add ST_ConstrainedDelaunayTriangles SFCGAL function (Darafei
+         Praliaskouski)
+**Enhancements**
+* 4341, Using "support function" API in PgSQL 12+ to replace SQL inlining
+as the mechanism for providing index support under ST_Intersects, et al
+* 4330, postgis_restore OOM when output piped to an intermediate process
+(Hugh Ranalli)
+* 4322, Support for Proj 6+ API, bringing more accurate datum transforms
+and support for WKT projections
+* 4153, ST_Segmentize now splits segments proportionally (Darafei
+Praliaskouski).
+* 4162, ST_DWithin documentation examples for storing geometry and
+radius in table (Darafei Praliaskouski, github user Boscop).
+* 4161 and #4294, ST_AsMVTGeom: Shortcut geometries smaller than the
+resolution (Raúl Marín)
+* 4176, ST_Intersects supports GEOMETRYCOLLECTION (Darafei Praliaskouski)
+* 4181, ST_AsMVTGeom: Avoid type changes due to validation (Raúl Marín)
+* 4183, ST_AsMVTGeom: Drop invalid geometries after simplification (Raúl Marín)
+* 4196, Have postgis_extensions_upgrade() package unpackaged extensions
+(Sandro Santilli)
+* 4215, Use floating point compare in ST_DumpAsPolygons (Darafei Praliaskouski)
+* 4155, Support for GEOMETRYCOLLECTION, POLYGON, TIN, TRIANGLE in
+ST_LocateBetween and ST_LocateBetweenElevations (Darafei Praliaskouski)
+* 2767, Documentation for AddRasterConstraint optional parameters (Sunveer Singh)
+* 4244, Avoid unaligned memory access in BOX2D_out (Raúl Marín)
+* 4139, Make mixed-dimension ND index build tree correctly (Darafei Praliaskouski,
+Arthur Lesuisse, Andrew Gierth, Raúl Marín)
+* 4262, Document MULTISURFACE compatibility of ST_LineToCurve (Steven Ottens)
+* 4276, ST_AsGeoJSON documentation refresh (Darafei Praliaskouski)
+* 4292, ST_AsMVT: parse JSON numeric values with decimals as doubles (Raúl Marín)
+* 4300, ST_AsMVTGeom: Always return the simplest geometry (Raúl Marín)
+* 4301, ST_Subdivide: fix endless loop on coordinates near coincident to bounds
+(Darafei Praliaskouski)
+* 4289, ST_AsMVTGeom: Transform coordinates space before clipping (Raúl Marín)
+* 4272, Improve notice message when unable to compute stats (Raúl Marín)
+* 4313, #4307, PostgreSQL 12 compatibility (Laurenz Albe, Raúl Marín)
+* 4299, #4304, ST_GeneratePoints is now VOLATILE. IMMUTABLE version with
+seed parameter added. (Mike Taves)
+* 4278, ST_3DDistance and ST_3DIntersects now support Solid TIN and Solid
+POLYHEDRALSURFACE (Darafei Praliaskouski)
+* 4348, ST_AsMVTGeom (GEOS): Enforce validation at all times (Raúl Marín)
+* 4295, Allow GEOMETRYCOLLECTION in ST_Overlaps, ST_Contains, ST_ContainsProperly,
+ST_Covers, ST_CoveredBy, ST_Crosses, ST_Touches, ST_Disjoint, ST_Relate,
+ST_Equals (Esteban Zimányi)
+* 4340, ST_Union aggregate now can handle more than 1 GB of geometries
+* 4378, Allow passing TINs as input to GEOS-backed functions (Darafei
+Praliaskouski)
+* 4368, Reorder LWGEOM struct members to minimize extra padding (Raúl Marín)
+* 4141, Use uint64 to handle row counts in the topology extension (Raúl Marín)
+* 4225, Upgrade tiger to use tiger 2018 census files
+* 4412, Support ingesting rasters with NODATA=NaN (Darafei Praliaskouski)
+* 4413, Raster tile size follows GeoTIFF block size on raster2pgsql -t auto
+* 4422, Modernize Python 2 code to get ready for Python 3 (Christian Clauss)
+* 4394, Allow FULL OUTER JOIN on geometry equality operator (Darafei Praliaskouski)
+ones faster. (Darafei Praliaskouski)
+* 4403, Support for shp2pgsql ability to reproject with copy mode (-D) (Regina Obe)
+* 4410, More descriptive error messages about SRID mismatch (Darafei Praliaskouski)
+* 4399, TIN and Triangle output support in all output functions (Darafei
+Praliaskouski)
+* 3719, Impose minimum number of segments per arc during linearization
+(Dan Baston / City of Helsinki, Raúl Marín)
+* 4277, ST_GeomFromGeoJSON now marks SRID=4326 by default as per RFC7946,
+ST_AsGeoJSON sets SRID in JSON output if it differs from 4326.
+* 3979, postgis_sfcgal_noop() round trip function (Lucas C. Villa Real)
+* 4328, ST_3DIntersects for 2D TINs. (Darafei Praliaskouski)
+* 4509, Update geocoder for tiger 2019 (Regina Obe)
+**Minor Breaking Changes**
+* 4267, Bump minimum GEOS version to 3.6 (Regina Obe, Darafei Praliaskouski)
+* 4229, Dropped support for PostgreSQL < 9.5. (Darafei Praliaskouski)
+* 4260, liblwgeom headers are not installed anymore.
+         If your project depends on them available, please use
+         librttopo instead. (Darafei Praliaskouski)
+* 4258, Remove SFCGAL support for `ST_Area`, `ST_Distance`, `ST_Intersection`,
+         `ST_Difference`, `ST_Union`, `ST_Intersects`, `ST_3DIntersects`, `ST_3DDistance`
+         and `postgis.backend` switch (Darafei Praliaskouski)
+* 4267, Enable Proj 6 deprecated APIs (Darafei Praliaskouski, Raúl Marín)
+* 4268, Bump minimum SFCGAL version to 1.3.1 (Darafei Praliaskouski)
+* 4331, ST_3DMakeBox now returns error instead of a miniscule box (Regina Obe)
+* 4342, Removed "versioned" variants of `ST_AsGeoJSON` and `ST_AsKML` (Paul Ramsey)
+* 4356, ST_Accum removed. Use array_agg instead. (Darafei Praliaskouski)
+* 4334, Fix upgrade issues related to renamed function parameters (Raúl Marín)
diff --git a/content/post/2020/08-15_postgis-patches.md b/content/post/2020/08-15_postgis-patches.md
index bc7eb60..1289fd1 100644
--- a/content/post/2020/08-15_postgis-patches.md
+++ b/content/post/2020/08-15_postgis-patches.md
@@ -34,7 +34,7 @@ advantage of features new in PostgreSQL 12.
 * [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/2.5.5/NEWS)
 * PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-2.5.5.pdf)
 * [html doc download]({{< loc "postgis.release_docs">}}/doc-html-2.5.5.tar.gz)
-* html online [en]({{ site.root }}docs/manual-2.5) [de]({{ site.root }}docs/manual-2.5/postgis-de.html) [ja]({{ site.root }}docs/manual-2.5/postgis-ja.html)
 * [epub doc download]({{< loc "postgis.release_docs">}}/postgis-2.5.5.epub)
 **2.4.9**
@@ -44,7 +44,7 @@ This release supports PostgreSQL 9.3-10.
 * [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/2.4.9/NEWS)
 * PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-2.4.9.pdf)
 * [html doc download]({{< loc "postgis.release_docs">}}/doc-html-2.4.9.tar.gz)
-* html online [en]({{ site.root }}docs/manual-2.4)
 * [epub doc download]({{< loc "postgis.release_docs">}}/postgis-2.4.9.epub)
@@ -53,25 +53,25 @@ View all [closed tickets for 3.0.2, 2.5.5, 2.4.9][1].
 After installing the binaries or after running pg_upgrade:
 For PostGIS 2.5 and 3.0 do:
-{% geshi 'sql' %}
+```postgres
 SELECT postgis_extensions_upgrade();
-{% endgeshi %}
 For PostGIS 2.4 do:
-{% geshi 'sql' %}
+```postgres
-{% endgeshi %}
-{% geshi 'sql' %}
+```postgres
-{% endgeshi %}
diff --git a/content/post/2021/09-04_postgis-patches.md b/content/post/2021/09-04_postgis-patches.md
index 9b30890..62f2c5a 100644
--- a/content/post/2021/09-04_postgis-patches.md
+++ b/content/post/2021/09-04_postgis-patches.md
@@ -20,7 +20,7 @@ This release supports PostgreSQL 9.6-14.
 * [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.1.4/NEWS)
 * PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.1.4.pdf)
 * [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.1.4.tar.gz)
-* html online [en]({{ site.root }}docs/manual-3.1)
+* html online [en]({{< loc "site.root">}}docs/manual-3.1)
 * [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.1.4.epub)
 **3.0.4**
@@ -40,25 +40,25 @@ After installing the binaries or after running pg_upgrade:
 For PostGIS 3.1, 3.0, 2.5
 do below which will upgrade all your postgis extensions.
-{% geshi 'sql' %}
+```postgres
-{% endgeshi %}
 For PostGIS 2.4 and below do:
-{% geshi 'sql' %}
+```postgres
-{% endgeshi %}
-{% geshi 'sql' %}
+```postgres
-{% endgeshi %}
diff --git a/content/post/2021/09-11_postgis-3.2.0alpha1.md b/content/post/2021/09-11_postgis-3.2.0alpha1.md
index 954df52..39fd1e1 100644
--- a/content/post/2021/09-11_postgis-3.2.0alpha1.md
+++ b/content/post/2021/09-11_postgis-3.2.0alpha1.md
@@ -22,7 +22,7 @@ This release supports PostgreSQL 9.6-14.
 * [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.2.0alpha1/NEWS)
 * PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.2.0alpha1.pdf)
 * [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.2.0alpha1.tar.gz)
-* html online [en]({{ site.root }}docs/manual-3.2)
+* html online [en]({{< loc "site.root">}}docs/manual-3.2)
 * [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.2.0alpha1.epub)
 Details of this release can be found in NEWS file:
@@ -119,9 +119,9 @@ After installing the binaries or after running pg_upgrade:
-{% geshi 'sql' %}
+```postgres
-{% endgeshi %}
 [1]: https://trac.osgeo.org/postgis/query?status=closed&resolution=fixed&milestone=PostGIS+3.2.0&col=id&col=summary&col=milestone&col=status&col=type&col=priority&col=component&order=priority
diff --git a/content/post/2021/10-23_postgis-3.2.0beta1.md b/content/post/2021/10-23_postgis-3.2.0beta1.md
index 7e745c0..2eaf596 100644
--- a/content/post/2021/10-23_postgis-3.2.0beta1.md
+++ b/content/post/2021/10-23_postgis-3.2.0beta1.md
 * [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.2.0beta1/NEWS)
 * PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.2.0beta1.pdf)
 * [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.2.0beta1.tar.gz)
 * [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.2.0beta1.epub)
@@ -60,9 +60,9 @@ After installing the binaries or after running pg_upgrade:
-{% geshi 'sql' %}
+```postgres
-{% endgeshi %}
diff --git a/content/post/2021/11-26_postgis-3.2.0beta2.md b/content/post/2021/11-26_postgis-3.2.0beta2.md
index 4a2f17e..9cdce92 100644
--- a/content/post/2021/11-26_postgis-3.2.0beta2.md
+++ b/content/post/2021/11-26_postgis-3.2.0beta2.md
@@ -23,7 +23,7 @@ This release supports PostgreSQL 9.6-14, GEOS 3.6 and higher, and proj 4.9 and h
 * [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.2.0beta2/NEWS)
 * PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.2.0beta2.pdf)
 * [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.2.0beta2.tar.gz)
 * [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.2.0beta2.epub)
@@ -57,9 +57,9 @@ After installing the binaries or after running pg_upgrade:
-{% geshi 'sql' %}
+```postgres
-{% endgeshi %}
diff --git a/content/post/2021/12-04_postgis-3.2.0beta3.md b/content/post/2021/12-04_postgis-3.2.0beta3.md
index 45042aa..a70094c 100644
--- a/content/post/2021/12-04_postgis-3.2.0beta3.md
+++ b/content/post/2021/12-04_postgis-3.2.0beta3.md
 * [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.2.0beta3/NEWS)
 * PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.2.0beta3.pdf)
 * [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.2.0beta3.tar.gz)
 * [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.2.0beta3.epub)
@@ -43,19 +43,19 @@ as to the true impact of real-world queries.
 If you are running PG14+, you can reenable it by doing
-{% geshi 'sql' %}
+```postgres
 ALTER OPERATOR FAMILY gist_geometry_ops_2d
 	USING gist
   ADD FUNCTION 11 (geometry)
   geometry_gist_sortsupport_2d (internal);
-{% endgeshi %}
 To revert the change:
-{% geshi 'sql' %}
+```postgres
 	USING gist
   DROP FUNCTION 11 (geometry);
-{% endgeshi %}
 and then reindex your gist indexes.
@@ -76,9 +76,9 @@ After installing the binaries or after running pg_upgrade:
 Do the below which will upgrade all your postgis extensions.
-{% geshi 'sql' %}
+```postgres
-{% endgeshi %}
diff --git a/content/post/2021/12-10_postgis-3.2.0rc1.md b/content/post/2021/12-10_postgis-3.2.0rc1.md
index 450c810..4a87bb3 100644
--- a/content/post/2021/12-10_postgis-3.2.0rc1.md
+++ b/content/post/2021/12-10_postgis-3.2.0rc1.md
 * [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.2.0rc1/NEWS)
 * PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.2.0rc1.pdf)
 * [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.2.0rc1.tar.gz)
 * [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.2.0rc1.epub)
@@ -41,19 +41,19 @@ as to the true impact of real-world queries.
-{% geshi 'sql' %}
+```postgres
 	USING gist
-{% endgeshi %}
-{% geshi 'sql' %}
+```postgres
 	USING gist
-{% endgeshi %}
@@ -63,9 +63,9 @@ After installing the binaries or after running pg_upgrade:
-{% geshi 'sql' %}
+```postgres
-{% endgeshi %}
diff --git a/content/post/2021/12-18_postgis-3.2.0.md b/content/post/2021/12-18_postgis-3.2.0.md
index d6c9762..823bd7d 100644
--- a/content/post/2021/12-18_postgis-3.2.0.md
+++ b/content/post/2021/12-18_postgis-3.2.0.md
@@ -31,7 +31,7 @@ This release supports PostgreSQL 9.6-14, GEOS 3.6 and higher, and proj 4.9 and h
 * [NEWS](https://git.osgeo.org/gitea/postgis/postgis/raw/tag/3.2.0/NEWS)
 * PDF docs [en]({{< loc "postgis.release_docs">}}/postgis-3.2.0.pdf) [de]({{< loc "postgis.release_docs">}}/postgis-3.2.0-de.pdf)
 * [html doc download]({{< loc "postgis.release_docs">}}/doc-html-3.2.0.tar.gz)
-* html online [en]({{ site.root }}docs/manual-3.2/) [de]({{ site.root }}docs/manual-3.2/postgis-de.html) [ja]({{ site.root }}docs/manual-3.2/postgis-ja.html) [ko_KR]({{ site.root }}docs/manual-3.2/postgis-ko_KR.html)
+* html online [en]({{< loc "site.root">}}docs/manual-3.2/) [de]({{< loc "site.root">}}docs/manual-3.2/postgis-de.html) [ja]({{< loc "site.root">}}docs/manual-3.2/postgis-ja.html) [ko_KR]({{< loc "site.root">}}docs/manual-3.2/postgis-ko_KR.html)
 * [epub doc download]({{< loc "postgis.release_docs">}}/postgis-3.2.0.epub)
@@ -49,19 +49,19 @@ as to the true impact of real-world queries.
-{% geshi 'sql' %}
+```postgres
 	USING gist
-{% endgeshi %}
-{% geshi 'sql' %}
+```postgres
 	USING gist
-{% endgeshi %}
diff --git a/content/post/2022/02-01_postgis-3.1.5.md b/content/post/2022/02-01_postgis-3.1.5.md
index 38da5b0..df08449 100644
--- a/content/post/2022/02-01_postgis-3.1.5.md
+++ b/content/post/2022/02-01_postgis-3.1.5.md
@@ -41,18 +41,18 @@ After installing the binaries or after running pg_upgrade:
-{% geshi 'sql' %}
+```postgres
-{% endgeshi %}
 For PostGIS 2.5 and below do:
-{% geshi 'sql' %}
+```postgres
-{% endgeshi %}
 If you come across any issues, feel free to report via our [ticket tracker](https://trac.osgeo.org/postgis)
 or [mailing list](https://lists.osgeo.org/listinfo/postgis-users) with details
diff --git a/layouts/shortcodes/loc.html b/layouts/shortcodes/loc.html
index 6c5093f..cf2f4dd 100644
--- a/layouts/shortcodes/loc.html
+++ b/layouts/shortcodes/loc.html
@@ -7,4 +7,5 @@
 {{ site.Params.postgis.release_source}}{{- print "" -}}
 {{- end }}
 {{- if eq $var "postgis.release_notes" }}{{ site.Params.postgis.release_notes}}{{- print "" -}}{{- end }}
+{{- if eq $var "site.root" }}{{ site.BaseURL}}{{- print "" -}}{{- end }}
Summary of changes:
 content/pages/windows_downloads.md             |   8 +-
 content/post/2019/03-11_postgis-patches.md     |  77 ++++++++++
 content/post/2019/05-26_postgis-3.0.0alpha1.md |  57 +++++++
 content/post/2019/06-02_postgis-3.0.0alpha2.md |  68 +++++++++
 content/post/2019/07-01_postgis-3.0.0alpha3.md |  76 ++++++++++
 content/post/2019/08-11_postgis-patches.md     |  87 +++++++++++
 content/post/2019/09-28_postgis-3.0.0beta1.md  |  75 ++++++++++
 content/post/2019/10-08_postgis-3.0.0rc1.md    |  69 +++++++++
 content/post/2019/10-13_postgis-3.0.0rc2.md    |  69 +++++++++
 content/post/2019/10-20_postgis-3.0.0.md       | 200 +++++++++++++++++++++++++
 content/post/2020/08-15_postgis-patches.md     |  16 +-
 content/post/2021/09-04_postgis-patches.md     |  14 +-
 content/post/2021/09-11_postgis-3.2.0alpha1.md |   6 +-
 content/post/2021/10-23_postgis-3.2.0beta1.md  |   6 +-
 content/post/2021/11-26_postgis-3.2.0beta2.md  |   6 +-
 content/post/2021/12-04_postgis-3.2.0beta3.md  |  14 +-
 content/post/2021/12-10_postgis-3.2.0rc1.md    |  14 +-
 content/post/2021/12-18_postgis-3.2.0.md       |  10 +-
 content/post/2022/02-01_postgis-3.1.5.md       |   8 +-
 layouts/shortcodes/loc.html                    |   1 +
 20 files changed, 830 insertions(+), 51 deletions(-)
 create mode 100644 content/post/2019/03-11_postgis-patches.md
 create mode 100644 content/post/2019/05-26_postgis-3.0.0alpha1.md
 create mode 100644 content/post/2019/06-02_postgis-3.0.0alpha2.md
 create mode 100644 content/post/2019/07-01_postgis-3.0.0alpha3.md
 create mode 100644 content/post/2019/08-11_postgis-patches.md
 create mode 100644 content/post/2019/09-28_postgis-3.0.0beta1.md
 create mode 100644 content/post/2019/10-08_postgis-3.0.0rc1.md
 create mode 100644 content/post/2019/10-13_postgis-3.0.0rc2.md
 create mode 100644 content/post/2019/10-20_postgis-3.0.0.md
hooks/post-receive
postgis.net
