[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-212-gbf3face55
Mon Sep 4 17:47:59 PDT 2023
the project "PostGIS".
       via  bf3face554efc131802a2e5660dd9d1e3c0b0e87 (commit)
      from  9edf33873d236da34f0092c59a2827091db99716 (commit)
revisions in full, below.
commit bf3face554efc131802a2e5660dd9d1e3c0b0e87
Author: Regina Obe <lr at pcorp.us>
Date:   Mon Sep 4 20:47:54 2023 -0400
    More fix of entities
diff --git a/doc/po/zh_Hans/using_postgis_dataman.xml.po b/doc/po/zh_Hans/using_postgis_dataman.xml.po
index de6068e25..efee54ad4 100644
--- a/doc/po/zh_Hans/using_postgis_dataman.xml.po
+++ b/doc/po/zh_Hans/using_postgis_dataman.xml.po
@@ -3032,7 +3032,7 @@ msgid ""
 "When using the \"&&\" operator, you can specify either a BOX3D as "
 "the comparison feature or a GEOMETRY. When you specify a GEOMETRY, however, "
 "its bounding box will be used for the comparison."
-msgstr "使用“&&”运算符时,可以指定比较特征是 BOX3D 还是几何。 但是,如果指定几何图形,则其边界框用于比较。"
+msgstr "使用“&&”运算符时,可以指定比较特征是 BOX3D 还是几何。 但是,如果指定几何图形,则其边界框用于比较。"
 #. Tag: para
 #: using_postgis_dataman.xml:1974
Summary of changes:
 doc/po/zh_Hans/using_postgis_dataman.xml.po | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
hooks/post-receive
