[postgis-tickets] [SCM] PostGIS branch master updated. 3.4.0rc1-219-gfb85d9269
Mon Sep 4 18:12:34 PDT 2023
the project "PostGIS".
       via  fb85d926921795ac82c0ca9c8dd93dc4b621d764 (commit)
       via  27b4fb8669bfb8dba6799710e2d851f5bd77b0a3 (commit)
       via  b9698d0268b631723ef1db61148aa4f3d92a844a (commit)
       via  3618f779bbcdd25ee9b94d905f701db687dca9d4 (commit)
       via  d1cd3a9a9dbee57fb90bfa31dbdd04bc005a4473 (commit)
       via  0d25bb7e3e0bc4bce034c072cd3f40531254e19d (commit)
      from  1765af0dec1b76362bf123d5511050c78ad1b6a3 (commit)
revisions in full, below.
commit fb85d926921795ac82c0ca9c8dd93dc4b621d764
Author: Zuochenwei <zuochenwei5 at gmail.com>
Date:   Tue Sep 5 01:03:32 2023 +0000
    Translated using Weblate (Chinese (Simplified))
    Currently translated at 8.1% (4 of 49 strings)
    Translation: postgis/reference_guc.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_gucxml/zh_Hans/
diff --git a/doc/po/zh_Hans/reference_guc.xml.po b/doc/po/zh_Hans/reference_guc.xml.po
index 395e3a6a9..ef906a4ab 100644
--- a/doc/po/zh_Hans/reference_guc.xml.po
+++ b/doc/po/zh_Hans/reference_guc.xml.po
@@ -6,7 +6,7 @@ msgstr ""
 "Project-Id-Version: build-pg 13\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2023-07-18 20:22+0000\n"
-"PO-Revision-Date: 2023-09-01 09:54+0000\n"
+"PO-Revision-Date: 2023-09-05 01:12+0000\n"
 "Last-Translator: Zuochenwei <zuochenwei5 at gmail.com>\n"
 "Language-Team: Chinese (Simplified) <https://weblate.osgeo.org/projects/"
 "postgis/reference_gucxml/zh_Hans/>\n"
@@ -61,7 +61,7 @@ msgstr ""
 #: reference_guc.xml:20
 #, no-c-format
 msgid "Availability: 2.1.0"
-msgstr ""
+msgstr "可用性:2.1.0"
 #. Tag: title
 #: reference_guc.xml:24 reference_guc.xml:70 reference_guc.xml:147
commit 27b4fb8669bfb8dba6799710e2d851f5bd77b0a3
    Currently translated at 2.7% (5 of 179 strings)
    Translation: postgis/extras_tigergeocoder.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/extras_tigergeocoderxml/zh_Hans/
diff --git a/doc/po/zh_Hans/extras_tigergeocoder.xml.po b/doc/po/zh_Hans/extras_tigergeocoder.xml.po
index cd653b700..832db64a7 100644
--- a/doc/po/zh_Hans/extras_tigergeocoder.xml.po
+++ b/doc/po/zh_Hans/extras_tigergeocoder.xml.po
@@ -7,7 +7,7 @@ msgstr ""
-"PO-Revision-Date: 2023-09-01 15:00+0000\n"
 "postgis/extras_tigergeocoderxml/zh_Hans/>\n"
@@ -355,7 +355,7 @@ msgstr ""
 #: extras_tigergeocoder.xml:1040
 #, no-c-format
-msgstr ""
+msgstr "可用性:2.1.0"
 #. Tag: refpurpose
 #: extras_tigergeocoder.xml:143
commit b9698d0268b631723ef1db61148aa4f3d92a844a
    Currently translated at 3.1% (10 of 320 strings)
    Translation: postgis/reference_processing.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_processingxml/zh_Hans/
diff --git a/doc/po/zh_Hans/reference_processing.xml.po b/doc/po/zh_Hans/reference_processing.xml.po
index 3ed63dffe..e188821c7 100644
--- a/doc/po/zh_Hans/reference_processing.xml.po
+++ b/doc/po/zh_Hans/reference_processing.xml.po
 "POT-Creation-Date: 2023-07-19 07:45+0000\n"
-"PO-Revision-Date: 2023-09-04 12:58+0000\n"
 "postgis/reference_processingxml/zh_Hans/>\n"
@@ -929,7 +929,7 @@ msgstr ""
 #: reference_processing.xml:901
 #, no-c-format
-msgstr ""
+msgstr "可用性:2.1.0"
 #. Tag: para
 #: reference_processing.xml:903
commit 3618f779bbcdd25ee9b94d905f701db687dca9d4
    Currently translated at 0.5% (6 of 1129 strings)
    Translation: postgis/reference_raster.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_rasterxml/zh_Hans/
diff --git a/doc/po/zh_Hans/reference_raster.xml.po b/doc/po/zh_Hans/reference_raster.xml.po
index 30e991a35..c7ec5fd0d 100644
--- a/doc/po/zh_Hans/reference_raster.xml.po
+++ b/doc/po/zh_Hans/reference_raster.xml.po
 "postgis/reference_rasterxml/zh_Hans/>\n"
@@ -1391,7 +1391,7 @@ msgstr ""
 #: reference_raster.xml:11648 reference_raster.xml:11741
 #, no-c-format
-msgstr ""
+msgstr "可用性:2.1.0"
 #. Tag: refpurpose
 #: reference_raster.xml:1244
commit d1cd3a9a9dbee57fb90bfa31dbdd04bc005a4473
Date:   Tue Sep 5 01:00:43 2023 +0000
    Currently translated at 75.1% (157 of 209 strings)
    Translation: postgis/reference_input.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_inputxml/zh_Hans/
diff --git a/doc/po/zh_Hans/reference_input.xml.po b/doc/po/zh_Hans/reference_input.xml.po
index 8b807a137..c22be19ff 100644
--- a/doc/po/zh_Hans/reference_input.xml.po
+++ b/doc/po/zh_Hans/reference_input.xml.po
 "postgis/reference_inputxml/zh_Hans/>\n"
@@ -1235,7 +1235,7 @@ msgstr ""
 #: reference_input.xml:1187
 #, no-c-format
 msgid "<para>Return a BOX2D from a GeoHash string.</para>"
-msgstr ""
+msgstr "<para>从 GeoHash 字符串返回 BOX2D。</para>"
 #. Tag: para
 #: reference_input.xml:1189
@@ -1244,6 +1244,8 @@ msgid ""
 "If no <varname>precision</varname> is specified ST_Box2dFromGeoHash returns "
 "a BOX2D based on full precision of the input GeoHash string."
 msgstr ""
+"如果未指定<varname>precision</varname>,ST_Box2dFromGeoHash 将返回基于输入 "
+"GeoHash 字符串的完整精度的 BOX2D。"
 #. Tag: para
 #: reference_input.xml:1191
@@ -1253,12 +1255,15 @@ msgid ""
 "that many characters from the GeoHash to create the BOX2D. Lower precision "
 "values results in larger BOX2Ds and larger values increase the precision."
 msgstr ""
+"如果指定<varname>precision</varname>,ST_Box2dFromGeoHash 将使用 GeoHash "
+"中的许多字符来创建 BOX2D。 较低的精度值会导致较大的 "
+"BOX2D,较大的值会提高精度。"
 #. Tag: para
 #: reference_input.xml:1193 reference_input.xml:1234 reference_input.xml:1563
 #, no-c-format
-msgstr ""
+msgstr "可用性:2.1.0"
 #. Tag: para
 #: reference_input.xml:1203
@@ -1267,12 +1272,14 @@ msgid ""
 ", <xref linkend=\"ST_GeomFromGeoHash\"/>, <xref "
 "linkend=\"ST_PointFromGeoHash\"/>"
 msgstr ""
+", <xref linkend=\"ST_GeomFromGeoHash\"/>, <xref linkend=\"ST_PointFromGeoHash"
 #. Tag: refpurpose
 #: reference_input.xml:1212
 #, no-c-format
 msgid "Return a geometry from a GeoHash string."
-msgstr ""
+msgstr "从 GeoHash 字符串返回几何图形。"
 #. Tag: funcprototype
 #: reference_input.xml:1217
@@ -1283,6 +1290,10 @@ msgid ""
 "<paramdef choice=\"opt\"><type>integer </type> "
 "<parameter>precision=full_precision_of_geohash</parameter></paramdef>"
 msgstr ""
+"<funcdef>geometry <function>ST_GeomFromGeoHash</function></funcdef> "
+"<paramdef><type>text </type> <parameter>geohash</parameter></paramdef> "
+"<paramdef choice=\"opt\"><type>integer </type> "
+"<parameter>precision=full_precision_of_geohash</parameter></paramdef>"
 #. Tag: para
 #: reference_input.xml:1228
@@ -1290,7 +1301,7 @@ msgstr ""
 msgid ""
 "Return a geometry from a GeoHash string. The geometry will be a polygon "
 "representing the GeoHash bounds."
-msgstr ""
+msgstr "从 GeoHash 字符串返回几何图形。 几何图形将是表示 GeoHash 边界的多边形。"
 #. Tag: para
 #: reference_input.xml:1230
@@ -1299,6 +1310,8 @@ msgid ""
 "If no <varname>precision</varname> is specified ST_GeomFromGeoHash returns a "
 "polygon based on full precision of the input GeoHash string."
 msgstr ""
+"如果未指定<varname>precision</varname>,ST_GeomFromGeoHash 返回基于输入 "
+"GeoHash 字符串的完整精度的多边形。"
 #. Tag: para
 #: reference_input.xml:1232
@@ -1307,6 +1320,8 @@ msgid ""
 "If <varname>precision</varname> is specified ST_GeomFromGeoHash will use "
 "that many characters from the GeoHash to create the polygon."
 msgstr ""
+"如果指定<varname>precision</varname>,ST_GeomFromGeoHash 将使用 GeoHash "
+"中的那么多字符来创建多边形。"
 #. Tag: para
 #: reference_input.xml:1244
@@ -1315,6 +1330,8 @@ msgid ""
 ",<xref linkend=\"ST_Box2dFromGeoHash\"/>, <xref "
 msgstr ""
+",<xref linkend=\"ST_Box2dFromGeoHash\"/>, <xref linkend=\"ST_PointFromGeoHash"
 #. Tag: refpurpose
 #: reference_input.xml:1251
@@ -1322,14 +1339,14 @@ msgstr ""
 msgid ""
 "Takes as input GML representation of geometry and outputs a PostGIS geometry "
 "object"
-msgstr ""
+msgstr "将几何图形的 GML 表示形式作为输入并输出 PostGIS 几何对象"
 #. Tag: para
 #: reference_input.xml:1270
 #, no-c-format
 msgid ""
 "Constructs a PostGIS ST_Geometry object from the OGC GML representation."
-msgstr ""
+msgstr "根据 OGC GML 制图表达生成 PostGIS ST_Geometry对象。"
 #. Tag: para
 #: reference_input.xml:1271
@@ -1337,7 +1354,8 @@ msgstr ""
 msgid ""
 "ST_GeomFromGML works only for GML Geometry fragments. It throws an error if "
 "you try to use it on a whole GML document."
-msgstr ""
+msgstr "ST_GeomFromGML仅适用于 GML 的几何部分。 尝试将其用于整个 GML "
+"文档时会引发错误。"
 #. Tag: para
 #: reference_input.xml:1272
@@ -1350,18 +1368,24 @@ msgid ""
 "GML standards, cf: <ulink url=\"http://www.opengeospatial.org/standards/"
 "gml\">http://www.opengeospatial.org/standards/gml</ulink>:"
 msgstr ""
+"支持的 OGC GML 版本包括:<itemizedlist><listitem><para>GML 3.2.1 "
+"命名空间</para></listitem><listitem><para>GML 3.1.1 简单功能配置文件 SF-2("
+"向后兼容 GML 3.1.0 和 3.0.0)</para></listitem><listitem><para>GML 2.1."
+"2</para></listitem></itemizedlist>有关 OGC GML 标准,请参阅<ulink url=\"http"
+"://www.opengeospatial.org/standards/gml\">http://www.opengeospatial.org/"
+"standards/gml</ulink>"
 #. Tag: para
 #: reference_input.xml:1288 reference_input.xml:1485
 #, no-c-format
 msgid "Availability: 1.5, requires libxml2 1.6+"
-msgstr ""
+msgstr "可用性:需要 1.5 libxml2 1.6+"
 #. Tag: para
 #: reference_input.xml:1290 reference_input.xml:1487
 #, no-c-format
 msgid "Enhanced: 2.0.0 default srid optional parameter added."
-msgstr ""
+msgstr "增强:2.0.0 引入了多面体曲面支持和 TIN 支持。"
 #. Tag: para
 #: reference_input.xml:1294
@@ -1371,6 +1395,9 @@ msgid ""
 "instance). As PostGIS geometries don't, ST_GeomFromGML convert the whole "
 "geometry to 2D if a missing Z dimension is found once."
 msgstr ""
+"GML 允许混合维度(例如,同一 MultiGeometry 内的 2D 和 3D)。 由于 PostGIS "
+"几何图形不这样做,如果一旦发现缺失的 Z 维度,ST_GeomFromGML "
+"会将整个几何图形转换为 2D。"
 #. Tag: para
 #: reference_input.xml:1296
@@ -1381,6 +1408,9 @@ msgid ""
 "root node. If no srsName attribute available for the GML root node, the "
 "function throw an error."
 msgstr ""
+"GML 支持同一 MultiGeometry 内的混合 SRS。 由于 PostGIS 几何图形不这样做,"
+"因此在本例中 ST_GeomFromGML 会将所有子几何图形重新投影到 SRS 根节点。 如果 "
+"GML 根节点没有可用的 srsName 属性,则该函数会抛出错误。"
 #. Tag: para
 #: reference_input.xml:1298
commit 0d25bb7e3e0bc4bce034c072cd3f40531254e19d
    Currently translated at 5.3% (7 of 130 strings)
    Translation: postgis/reference_sfcgal.xml
    Translate-URL: https://weblate.osgeo.org/projects/postgis/reference_sfcgalxml/zh_Hans/
diff --git a/doc/po/zh_Hans/reference_sfcgal.xml.po b/doc/po/zh_Hans/reference_sfcgal.xml.po
index 2d6621c41..4718b1507 100644
--- a/doc/po/zh_Hans/reference_sfcgal.xml.po
+++ b/doc/po/zh_Hans/reference_sfcgal.xml.po
 "postgis/reference_sfcgalxml/zh_Hans/>\n"
@@ -80,7 +80,7 @@ msgstr ""
 #: reference_sfcgal.xml:1156
 #, no-c-format
-msgstr ""
+msgstr "可用性:2.1.0"
 #. Tag: para
 #: reference_sfcgal.xml:39 reference_sfcgal.xml:74 reference_sfcgal.xml:107
Summary of changes:
 doc/po/zh_Hans/extras_tigergeocoder.xml.po |  4 +--
 doc/po/zh_Hans/reference_guc.xml.po        |  4 +--
 doc/po/zh_Hans/reference_input.xml.po      | 50 ++++++++++++++++++++++++------
 doc/po/zh_Hans/reference_processing.xml.po |  4 +--
 doc/po/zh_Hans/reference_raster.xml.po     |  4 +--
 doc/po/zh_Hans/reference_sfcgal.xml.po     |  4 +--
 6 files changed, 50 insertions(+), 20 deletions(-)
hooks/post-receive
