[postgis-users] Polygon contains with Lat/Lon
Michael O'Sullivan mos at i3sp.com
Tue Feb 25 04:06:24 PST 2003
Hi all,
I have a question on finding out whether a given point is contained by a
polygon when using a geographic projection i.e. Lat/Long polygons.
I am currently using the dataset below
as a basis for performing isAtSea/OnLand queries.
The dataset is a set of polygons of lat/long positions. The data is
quite detailed (polygons with over 100,000 points).
I have managed to convert the data to postgis format and loaded it into
my database. I saw someone did this on the mailing list a year or two
ago but the file they had provided was corrupted and gzip was unable to
uncompress all the file. If anyone is interested in this data I can send
you a perl script to parse the gshhs data sets and produce postgis copy
Anyway, I have been using the ~ operator to locate Polygons in my
database which contain a point. Unfortunately the bounding box nature of
the ~ operator is causing points to be contained by multiple countries,
as the bounding box of the polygons end up including other countries
(and ocean positions).
I have seen a few emails in the archive regarding truly_inside, and
people questioning how to determine if a given point is inside a
polygon. Having read the postgis doco on functions I can't see anything
that looks like it will help me apart from truly_inside.
Looking at
The doco says
returns true if any part of B is within the bounding box of A.
I have tried using this but I am not sure if it is OK to use this with
Lat/Lon coords. I am seeing the opposite results to doco
I see it return true if any part of A is within the bounding box of B
navitag=# select summary(the_geom) from testtable where gid = 1;
  Object 0 is a POLYGON() with 1 rings
      + ring 0 has 169598 points
navitag=# select extent(the_geom) from testtable where gid =1;
  BOX3D(-179.99844 -34.83044 0,180 77.71958 0)
(1 row)
navitag=# select truly_inside(GeometryFromText('POINT(151 -33)',4269),
(1 row)
navitag=# select truly_inside(the_geom, GeometryFromText('POINT(151
-33)',4269)) from testtable where gid = 1;
(1 row)
I see that the distance function returns 0 if a point is inside a
polygon - but I am not in a cartesian coordinate space (I am in lat
long) - so that isn't an option. I don't think projection into a
cartesian corrdinate system is an option because the extent of these
polygons is so large.
Can anybody suggest how I might go about this? Am I on the correct path
with truly_inside?
Thanks in advance,
Michael O'Sullivan <mos at i3sp.com>
"A good man always knows his limitations" - HC
