[postgis-users] && operator memory leak
Carl Anderson carl.anderson at vadose.org
Sun Mar 7 18:27:15 PST 2004
Is anyone actively working on the memory leak in the gist && operator.
Or can anyone give me a heads up start point?
I have had enough of partitioning queries to work around an out ouf
memory condition and willing to delve into this issue.
the issue manifests most simply with a gist index on the_geom for both
tables and
select 1 from mytab
   where
     exists ( select 1
                from othertab
                  where othertab.the_geom && mytab.the_geom
with
   mytab ~ 100 thousand tuples
and
   othertab ~ 1 million tuples
much more than 3Gb of real memory is required during the query.
my datasets have much more than 1 million tuples.
C.
Carl Anderson
