[postgis-users] cygwin installer : how to change data directory
Steffen Macke sdteffen at web.de
Tue Mar 9 21:22:24 PST 2004
> PostGIS cygwin installer
> W2K
> I want to use another drive for postgresql data. What is the best and
> easiest method ?
Are your referring to the Cygwin PostGIS installer from
I haven't thought about adding the possibility to change the
data directory, but this should be relatively easy.
I've added RFE #913282 in order not to forget about this issuefor - see
However, this will take some time as we're very busy right now.
For the time being, you could have a look at the installer sources and
adjust the path in the related shell script and recompile the installer.
