[postgis-users] Re: Win32 PostgreSQL 7.5/PostGIS snapshot
Mark Cave-Ayland m.cave-ayland at webbased.co.uk
Fri May 28 10:40:42 PDT 2004
Hi Emil,
Thanks for the feedback regarding the performance of the Win32
PGSQL/PostGIS snapshot - it's good to hear that someone else has managed
to get it working successfully. It will be interesting to see if other
people experience the same level of performance that you have, and how
different it will be to tune PostgreSQL for Win32. I'll keep an eye on
the list for other reports of BSOD when restarting while the server is
still active, and if it is a problem then I shall mention it to the
PostgreSQL-Win32 people.
Many thanks,
Mark.
Mark Cave-Ayland
Webbased Ltd.
Tamar Science Park
Derriford
Plymouth
PL6 8BX
England
Tel: +44 (0)1752 764445
Fax: +44 (0)1752 764446
This email and any attachments are confidential to the intended
recipient and may also be privileged. If you are not the intended
recipient please delete it from your system and notify the sender. You
should not copy it or use it for any purpose nor disclose or distribute
its contents to any other person.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Emil Zegers
> Sent: 28 May 2004 11:49
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Re: Win32 PostgreSQL 7.5/PostGIS snapshot
> Hello Mark,
> Your Win32 PostgreSQL 7.5/PostGIS snapshot is working great!
> This morning I downloaded and installed the newest version
> with GiST index patch.
> Imported some shapefile data (point file with >88000 points)
> and made indexes on it.
> I'm viewing the data through a MapServer client.
> Performance is great and the database is stable too on my
> Windows 2000 system.
> About the batch files running order: I run env.bat before
> initdb.bat otherwise the path is not correct.
> Thanx for the 'Ctrl-C' tip to shutdown the server.
> If I restart the system without shutting down I get a BSOD
> before rebooting.
> Again, thanks for sharing this software.
> Best regards,
> Groeten,
> Emil Zegers
> De Straat Milieu-adviseurs
> Divisie Informatisering
> 026 7513902
> 06 22965585
> http://www.destraat.nl
> ______________________________________________________
>  This message has been checked for all known viruses
> postgis-users mailing list postgis-users at postgis.refractions.net
