[postgis-users] Postgis to ESRI shape file encoding problem
Ervin Ramonllari ervin.ramonllari at hotmail.com
Mon Jul 21 03:33:54 PDT 2008
I tried this way :
ALTER DATABASE DBIPRS SET PGCLIENTENCODING to 'Latin2'
but i got the error:
ERROR: unrecognized configuration parameter "pgclientencoding"
SQL state: 42704
> Date: Sat, 19 Jul 2008 14:37:37 +0200
> From: sdteffen at gmail.com
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] Postgis to ESRI shape file encoding problem
> You can also try to set the environment variable PGCLIENTENCODING to the
> encoding value you need (e.g. LATIN2).
> Steffen
> >> I'm trying to export some data from a Postgresql database encoded in UTF-8
> >> into some ESRI shape files.
> >> I'm using PostGIS Dumper (pgsql2shp).
> postgis-users mailing list
_________________________________________________________________
Discover the new Windows Vista
http://search.msn.com/results.aspx?q=windows+vista&mkt=en-US&form=QBRE
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080721/d713bca0/attachment.html>
