[postgis-users] postgis slow performance
Paragon Corporation lr at pcorp.us
Thu Aug 27 21:31:28 PDT 2009
Yes an explain would help.  My guess is that since both PostGIS and TSearch
use GIST.  I assume there is a GIST index on your tsearch vectory query?
One will be selected first over the other and perhaps that order is wrong.
I'm not sure what the difference in speeds are between the 2 if any and
probably depends on your dataset as well.
My guess is though that the btree index will most always win out first so in
the first case -- teh order of application of filters is more predicatable
and probably more efficient.
8.1 is also kind of old and there have been a lot of planner improvements
made since then and improvements in GIST as well as I recall.
Hope that helps,
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Ben
Sent: Thursday, August 27, 2009 9:49 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] postgis slow performance
I probably can't help, but am interested in the optimisation of my own
However, without knowing a bit more about your setup I doubt anyone else can
The output of
select postgis_full_version();
is a good starting point.
Other details like EXPLAIN output, how big is the table, what other columns
are there, is it in a separate tablespace, etc. are often useful.
Maybe submit that now so when other's look at it they have a bit more to
work on.
On 28/08/2009, at 1:35 AM, Narayanan, Divya wrote:
We were testing some queries to improve performance and found that the
queries using PostGIS were slower than those that did not.
I've included one of the queries tested
Query with PostGIS
SELECT ntb.id
FROM navteq as ntb
WHERE ( ntb.positioned_tsv @@ '(hotel|hodels|hoteles)'::tsquery)
AND (latitude>34.00846 AND latitude<34.09855 AND longitude>-118.29926 AND
Query time: 1 second
Query using postgis:
SELECT ntb.id
FROM navteq_xtd_noothers as ntb
AND geom && ST_SetSRID(ST_MakeBox2D(ST_Point(-118.29926,
34.00846),ST_Point(-118.1907, 34.09855)),4269)
Query time: 4 seconds
The latitude and longitude columns are indexed. The geom column uses a GIST
index. We're using Postgres v 8.1. Is there something we're doing wrong?
Please let me know if you need more information.
Ben Madin
t : +61 8 9192 5455
f : +61 8 9192 5535
m : 0448 887 220
Broome   WA   6725
ben at remoteinformation.com.au
Out here, it pays to know...
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090828/ba8ad091/attachment.html>
