[postgis-users] Install postgis on a different schema
Andrea Peri aperi2007 at gmail.com
Fri Oct 9 00:01:22 PDT 2009
Regina
thx for hints.
I think you have right.
Is better to install on different databases.
And I move definitively on this choice.
Only a last question
As you know is possible from inside a session on a database to read
geometry data on another table on another database (same postgres instance
of course).
Regards,
Andrea.
>In theory you can but you shouldn't.  It would get very confusing and you
>would quickly loose your sanity as you would have to schema qualify each
>postgis function, geometry type etc and it wouldn't work with any third
>party tools correctly because they most likely will not schema qualify.  I
>would avoid it.
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20091009/775aae54/attachment.html>
