[postgis-users] Diagram of Voronoï to Squelettisation of polygon
j.rolland jrmrolland at aol.com
Fri Dec 10 10:16:22 PST 2010
Hi Daniel,
Of course that I am interested, say me how I can contribute my share.
As I indicate it in my blog, I can develop a function which turns over the
skeleton from a polygon. Give me your specifications and I would study them.
cordially,
Jérôme
Daniel Kastl-3 wrote:
> Salut Jérôme,
> Thank you for sharing your blog article!
> I tried to recall my French from high school and thanks to nice
> screenshots
> and code samples I think I could mostly understand.
> Well, I thought your functions might be an interesting contribution to
> pgRouting project (http://www.pgrouting.org).
> We're trying to collect various routing and network analysis related
> functionality. Some voronoi and skeleton addition would for sure suite
> well.
> That way users could build some routable network out of river polygons for
> example. It might also help to build a routable graph for  maritime
> navigation. Probably there are a lot more use cases.
> Let me know if you're interested.
> Daniel
> 2010/12/9 j.rolland <jrmrolland at aol.com>
>> hi,
>> I have just set up on my blog at the following address
>> http://ageoguy.blogspot.com/2010/12/squ… ation.html
>> http://ageoguy.blogspot.com/2010/12/squ… ation.html  a tutorial (in
>> french)
>> which presents an algorithm of surface squelettisation of waterway
>> (POLYGON).
>> I provide an example like all the necessary functions and requests which
>> will enable you to obtain the skeleton of the waterway as you can see it
>> in
>> the capture below :
>> http://old.nabble.com/file/p30413623/skeleton5.jpg
>> regards,
>> Jérôme
>> View this message in context:
>> http://old.nabble.com/Diagram-of-Vorono%C3%AF-to-Squelettisation-of-polygon-tp30413623p30413623.html
>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl at georepublic.de
> Web: http://georepublic.de
View this message in context: http://old.nabble.com/Diagram-of-Vorono%C3%AF-to-Squelettisation-of-polygon-tp30413623p30428747.html
