[PROJ] Coordinate transformations between different WGS84 reference frames
Even Rouault even.rouault at spatialys.com
Thu Aug 4 08:39:44 PDT 2022
Luís,
so you're transforming from WGS 84 (G730) to WGS 84 (G1762). I highly
doubt that any PROJ version produced anything than a null transformation
for that, given there's no known (in EPSG database) direct
transformation between those 2 realizations.
That said, digging a bit, in EPSG, there's :
- a null transformation between WGS 84 (G730) and ITRF92 . Accuracy 0.2m
- a non-null time-dependent Helmert transformation between ITRF92 and
ITRF2008. Accuracy 0.01 m
- a null transformation between ITRF2008 and WGS 84 (G1762). Accuracy 0.01m
So if you do:
$ echo 20 10 0 2022.6 | cs2cs -d 8  "WGS 84 (G730)" ITRF92 | cs2cs -d 8
ITRF92 ITRF2008 | cs2cs -d 8 ITRF2008  "WGS 84 (G1762)"
20.00000101    9.99999995 -0.00107558 2022.6
(in practice you can keep omit the first and last cs2cs invokation)
As raised in many threads, PROJ could in theory be enhanced to infer
that itself, but it would be computationally and programmatically
complex to do so.
Even
Le 04/08/2022 à 17:13, Luí s Moreira de Sousa via PROJ a écrit :
> Dear all,
> This message reports to Proj 8.2.1. I am trying to reproduce an
> exercise I conducted some years ago with Proj 6 (maybe 7) transforming
> coordinates between different realisations of the WGS84 ensemble. I am
> using this formulation:
> $ cs2cs EPSG:9053 EPSG:9057
> 20 10
> 20dN 10dE 0.000
> My recollection was cs2cs producing visible differences in the order
> metres. With the current version the output is unchanged transforming
> between these geodesic CRS. Do I need to use an additional parameter?
> Or am I missing something else?
> Thank you.
> Luís
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220804/7557dc32/attachment.htm>
More information about the PROJ mailing list
