[PROJ] Could you please explain me why I can't project RDN2008 (EPSG:6706) to ERTF2000 (EPSG:9067) or ITRF2000 (EPGS:8997)
    Greg Troxel
    gdt at lexort.com
    Tue Jul 19 04:48:07 PDT 2022
Even Rouault <even.rouault at spatialys.com> writes:
> For RDN2008, there are 2 transformations available:
> - one from RDN2008 to ETRS89 (EPSG:4258), with a null Helmert
> transformation and a accuracy of 0 m. This is consistant with how you
> described RDN2008, and this transformation has the comment "RDN2008 is
> the second Italian realization of ETRS89"
A far more lengthy way forward might be:
  Italian geodetic authorities (whoever defined RDN2008) publish a
  transformation from RDN2008 to some modern ETRFyyyy, including an
  error estimate.
  They submit that to EPSG for inclusion.
  A new EPSG version is published.
  A proj release arrives with the new EPSG version.
  Meanwhile, you wait for the previous 4 steps.
I realize it doesn't solve your problem now, but authoritative
transforms with tight error estimates shorten the transform pipelines
that are used and lead to better answers.  The above avoids ETRS89.
> Afaik, RDN2008 is ETRS89 realization ETRF2000 epoch 2008.0.
If you believe that precisely, you could just relabel your data as being
ETRF2000 (assuming the standard epoch is 2008.0).
Or insert a transform similar to Even's sugggestion, perhaps with better
accuracy.  I would expect RDN2008/ETRF2000:2008.0 to be at the 0.01m
level -- but I am pretty clueless about ETRF details.
Desc: not available
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20220719/1b84c4d3/attachment.sig>
More information about the PROJ
