[PROJ] Equirectangular/Equidistant Cylindrical
Even Rouault even.rouault at spatialys.com
Wed Oct 12 13:38:46 PDT 2022
Le 12/10/2022 à 22:12, Andrew Patterson a écrit :
> Even,
> I can share both, but presumably I shouldn't (or can't?) post the PDF
> to the mailing list. Should I create an issue on GitHub and post the
> PDF and other information there?
yes please
> The transformation is from WGS84 into the CRS of the map (or in this
> case, PDF). We render the PDF in its native projection and the points
> in question are stored in lat/long in the KML file, so they are being
> projected from WGS84 to Equidistant Cylindrical and then transformed
> into pixels by a second stage transformation. The latter hasn't
> changed between the two versions of the app, so it's presumably the
> WGS84 -> Equidistant Cylindrical where the problem lies.
hum, weird, this is the most simple projection you can imagine...
> On Wed, Oct 12, 2022 at 2:48 PM Even Rouault
> <even.rouault at spatialys.com> wrote:
>     Andrew,
>     the PDF file would be needed to analyze this, as well as the
>     target CRS you are reprojecting into with your app.
>     I suspect that the "proj_create_from_database: crs not found"
>     error might come from the fact that the PDF contains a WKT string
>     with AUTHORITY["Esri","102422"], and PROJ currently only
>     understands "ESRI" as the authority, and not "Esri". It should
>     probably be laxer regarding that. That said, I'm not sure that
>     explains a difference in positioning. It is probably more that
>     recent PROJ versions can apply datum shifts more often than older
>     ones, so things might behave as expected.
>     Even
>     Le 12/10/2022 à 20:04, Andrew Patterson a écrit :
>>     Hello everyone!
>>     I posted an issue, #3186, involving Equidistant Cylindrical back
>>     in May. It was fixed (very quickly I might add) and I applied the
>>     patch to our version of PROJ without an issue, solving the problem.
>>     Since then, however, I've been given a PDF with an
>>     Equirectangular/Equidistant Cylindrical projection that is giving
>>     me some grief. My QA team has created a KMl file with three
>>     positions on this map that when imported to an earlier version of
>>     our app using GDAL 2.4, properly positioned the placemarks where
>>     they are expected. If I do the same with the current version of
>>     our app, running GDAL 3.4, these placemarks appear west & south
>>     of where they should be. I know I'm talking about GDAL here, but
>>     I'm pretty sure this is a PROJ issue for both the obvious reason
>>     that it's a transformation and for another that I'll get to
>>     momentarily.
>>     I downloaded GDAL binaries for 2.4 & 3.5.2 and ran gdalinfo
>>     -proj4 against the PDF file and I get the following outputs (I've
>>     removed everything but the WKTs & proj4 string):
>>     GDAL 2.4:
>>     Driver: PDF/Geospatial PDF
>>     Files: 11.2 - Cape Spear Path - Blackhead to Maddox Cove GEO.pdf
>>     Size is 1275, 1650
>>     Coordinate System is:
>>     PROJCS["WGS_1984_ARC_System_Zone_02",
>>         GEOGCS["GCS_WGS_1984",
>>             DATUM["WGS_1984",
>>     SPHEROID["WGS_84",6378137.0,298.257223563]],
>>             PRIMEM["Greenwich",0.0],
>>             UNIT["Degree",0.0174532925199433]],
>>         PROJECTION["Equirectangular"],
>>         PARAMETER["False_Easting",0.0],
>>         PARAMETER["False_Northing",0.0],
>>         PARAMETER["Central_Meridian",0.0],
>>         PARAMETER["Standard_Parallel_1",41.12682127],
>>         UNIT["Meter",1.0],
>>         AUTHORITY["Esri","102422"]]
>>     PROJ.4 string is:
>>     '+proj=eqc +lat_ts=41.12682127 +lat_0=0 +lon_0=0 +x_0=0 +y_0=0
>>     +datum=WGS84 +units=m +no_defs '
>>     GDAL 3.5.2:
>>     ERROR 1: PROJ: proj_create_from_database: crs not found
>>     Size is 1275, 1650
>>     PROJCRS["WGS_1984_ARC_System_Zone_02",
>>         BASEGEOGCRS["WGS 84",
>>             DATUM["World Geodetic System 1984",
>>                 ELLIPSOID["WGS 84",6378137,298.257223563,
>>                     LENGTHUNIT["metre",1]],
>>                 ID["EPSG",6326]],
>>             PRIMEM["Greenwich",0,
>>                 ANGLEUNIT["Degree",0.0174532925199433]]],
>>         CONVERSION["unnamed",
>>             METHOD["Equidistant Cylindrical",
>>                 ID["EPSG",1028]],
>>             PARAMETER["Latitude of 1st standard parallel",41.12682127,
>>                 ANGLEUNIT["Degree",0.0174532925199433],
>>                 ID["EPSG",8823]],
>>             PARAMETER["Longitude of natural origin",0,
>>                 ID["EPSG",8802]],
>>             PARAMETER["False easting",0,
>>                 LENGTHUNIT["metre",1],
>>                 ID["EPSG",8806]],
>>             PARAMETER["False northing",0,
>>                 ID["EPSG",8807]]],
>>         CS[Cartesian,2],
>>             AXIS["(E)",east,
>>                 ORDER[1],
>>                 LENGTHUNIT["metre",1,
>>                     ID["EPSG",9001]]],
>>             AXIS["(N)",north,
>>                 ORDER[2],
>>                     ID["EPSG",9001]]]]
>>     Data axis to CRS axis mapping: 1,2
>>     PROJ.4 string is:
>>     +datum=WGS84 +units=m +no_defs'
>>     Now, obviously the fact that it has a PROJ error at the top in
>>     3.5.2 is what points me at PROJ rather than GDAL, even if it
>>     wasn't likely just for being anyways just for being a
>>     transformation problem. Just to be on the safe side, I repealed
>>     the fix for #3186 to make sure that wasn't somehow causing this
>>     problem, and no, the problem remains even if I pull that fix out
>>     (of our app, not gdalinfo). I also tried feeding in the WKT from
>>     3.5.2 that the original WKT gets transformed into (this was a
>>     workaround for #3186) but that didn't help.
>>     Any idea on what the problem might be? I'm happy to provide more
>>     information if needed (and even the file it would help!). I'm
>>     assuming that error is the key piece though. Unfortunately, when
>>     I debug our app, I never hit that line; it always manages to pull
>>     the SRC from the cache (it never seems to ask for anything other
>>     than EPSG 4326)
>>     Any help would be greatly appreciated!
>>     Andrew Patterson
>>     Lead Software Architect
>>     Avenza Systems Inc.
>>     email: andrew at avenza.com
>>     phone: 416.487.5116
>>     _______________________________________________
>>     PROJ mailing list
>>     PROJ at lists.osgeo.org
>>     https://lists.osgeo.org/mailman/listinfo/proj
>     http://www.spatialys.com
>     My software is free, but my time generally not.
> Andrew Patterson
> Avenza Systems Inc.
> phone: 416.487.5116
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20221012/1857c5df/attachment-0001.htm>
More information about the PROJ mailing list
