[PROJ] Latitude of natural origin in Transverse Mercator
support at mnspoint.com support at mnspoint.com
Sat Jan 14 05:28:06 PST 2023
Hello,
You have angular latitudes on the globe and eastings and northings on
the resulting map plane. One should not mix them to stay out of trouble.
Janne.
Javier Jimenez Shaw kirjoitti 2023-01-13 16:28:
> Hi
> I have a question about Transverse Mercator.
> What is the impact of the parameter "Latitude of natural origin",
> compared with the "False Northing"? (apart from the fact that one is
> in degrees and the other in meters)
> Is there any difference on using a Latitude of natural origin of,
> let's say, 40 degrees, or compute the equivalent False Northing?
More information about the PROJ mailing list
