[PROJ] Area of usage (short) name
Martin Desruisseaux martin.desruisseaux at geomatys.com
Fri Jul 21 08:46:18 PDT 2023
Le 19/07/2023 à 00:02, Even Rouault a écrit :
> So basically the object model of osgeo::proj::metadata::Extent should
> likely be extended with a shortName() getter (the corresponding GeoAPI
> class that serves as the inspiration,
> http://www.geoapi.org/3.0/javadoc/org.opengis.geoapi/org/opengis/metadata/extent/Extent.html,
> has a single getDescription()), a C binding to get it (likely
> proj_get_area_of_use_ex2()), and
> AuthorityFactory::Private::createPropertiesSearchUsages() be modified
> to populate it.
Alternatively if the short area name can be seen as an identifier, then
in ISO 19115 model it can be a GeographicDescription. That description
can then be included among the values returned by
Extent.getGeographicElements().
Note: EPSG defines domain of validity not only by bounding boxes or by
names, but also by polygons stored as Shapefile. The latter could be
returned by BoundingPolygon in ISO 19115 model. Said otherwise,
Extent.getGeographicElements() allows to specify an area of validity in
different ways:
  * By identifier
  * By bounding box
  * By bounding polygon
Those 3 ways can be made available together.
     Martin
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230721/f4baa86b/attachment.htm>
More information about the PROJ mailing list
