[PROJ] Area of usage (short) name
Even Rouault even.rouault at spatialys.com
Fri Jul 21 09:48:51 PDT 2023
I don't think EPSG extent short names qualify as identifiers. They might
be altered between EPSG releases. Only their EPSG code is a true (ie
unmutable) identifier.
Le 21/07/2023 à 17:46, Martin Desruisseaux a écrit :
> Le 19/07/2023 à 00:02, Even Rouault a écrit :
>> So basically the object model of osgeo::proj::metadata::Extent should
>> likely be extended with a shortName() getter (the corresponding
>> GeoAPI class that serves as the inspiration,
>> http://www.geoapi.org/3.0/javadoc/org.opengis.geoapi/org/opengis/metadata/extent/Extent.html,
>> has a single getDescription()), a C binding to get it (likely
>> proj_get_area_of_use_ex2()), and
>> AuthorityFactory::Private::createPropertiesSearchUsages() be modified
>> to populate it.
> Alternatively if the short area name can be seen as an identifier,
> then in ISO 19115 model it can be a GeographicDescription. That
> description can then be included among the values returned by
> Extent.getGeographicElements().
> Note: EPSG defines domain of validity not only by bounding boxes or by
> names, but also by polygons stored as Shapefile. The latter could be
> returned by BoundingPolygon in ISO 19115 model. Said otherwise,
> Extent.getGeographicElements() allows to specify an area of validity
> in different ways:
>   * By identifier
>   * By bounding box
>   * By bounding polygon
> Those 3 ways can be made available together.
>     Martin
> PROJ mailing list
> PROJ at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/proj
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230721/e077c882/attachment-0001.htm>
More information about the PROJ mailing list
