[PROJ] Lowest Astronimical Tide reference surface in Geodetic TIFF Grid
Kristian Evers kristianevers at gmail.com
Thu Mar 16 09:50:26 PDT 2023
Jochem,
Coincidentally I am working on a similar grid for Denmark. I’ve used VERTICAL_OFFSET_VERTICAL_TO_VERTICAL, which seems to fit the bill.
/Kristian
> On 16 Mar 2023, at 17.34, Lesparre, Jochem via PROJ <proj at lists.osgeo.org> wrote:
> Hi PROJ mailing list,
> I am making a Geodetic TIFF Grid for the transformation between ETRS89 and Lowest Astronomical Tide of the Netherlands (https://epsg.org/crs_9289/ETRS89-LAT-NL-depth.html <https://epsg.org/crs_9289/ETRS89-LAT-NL-depth.html>).
> So this Geodetic TIFF Grid is of the type “VERTICAL_OFFSET_GEOGRAPHIC_TO_VERTICAL”. The description “geoid_undulation” seems unfitting, but if I choose something else like “lowest_astronomical_tide” PROJ doesn’t accept it:
> proj_create: Error 1029 (File not found or invalid): pipeline: Pipeline: Bad step definition: proj=vgridshift (File not found or invalid)
> cct: Bad transformation arguments - (File not found or invalid)
>     'cct -h' for help
> Should I use the description “geoid_undulation” nevertheless, should I use something else for type instead of “VERTICAL_OFFSET_GEOGRAPHIC_TO_VERTICAL”, or should I make a feature request to support a description name for “hydroid” models?
> Another, thing I was wondering is how to deal with the difference between height and depth. Should the Geodetic TIFF Grid specify ETRS89 + LAT NL depth (EPSG:9289) as target CRS, so EPSG would only have to make transformation code and a tif equivalent of the transformation method “Geog3D to Geog2D+Depth (txt)” (https://epsg.org/coord-operation-method_1115/Geog3D-to-Geog2D-Depth-txt.html <https://epsg.org/coord-operation-method_1115/Geog3D-to-Geog2D-Depth-txt.html>)? Or should the Geodetic TIFF Grid specify ETRS89 + LAT NL height (for which no EPSG code is available yet) as target CRS? I case of the latter, EPSG would need to make transformation code and an equivalent of the transformation method “Geog3D to Geog2D+GravityRelatedHeight (txt)” (https://epsg.org/coord-operation-method_1098/Geog3D-to-Geog2D-GravityRelatedHeight-txt.html <https://epsg.org/coord-operation-method_1098/Geog3D-to-Geog2D-GravityRelatedHeight-txt.html>), but also have to add an additional CRS code for LAT NL height, a Compound code ETRS89 + LAT NL height, and a transformation code LAT NL height to LAT NL depth based on “Height Depth Reversal” (https://epsg.org/coord-operation-method_1068/Height-Depth-Reversal.html <https://epsg.org/coord-operation-method_1068/Height-Depth-Reversal.html>).
> Best regards, Jochem
> Disclaimer:
> De inhoud van deze e-mail is vertrouwelijk en uitsluitend bestemd voor de geadresseerde(n).
> Gebruik, openbaarmaking, vermenigvuldiging, verspreiding en/of verstrekking van deze informatie aan derden is niet toegestaan.
> Op al onze producten en diensten zijn onze algemene leveringsvoorwaarden van toepassing
> [https://www.kadaster.nl/algemene-leveringsvoorwaarden <https://www.kadaster.nl/algemene-leveringsvoorwaarden>].
> Disclaimer:
> This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed.
> If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited.
> Our general terms and conditions of delivery apply to all our products and services
> [https://www.kadaster.com/general-terms-and-conditions <https://www.kadaster.com/general-terms-and-conditions>].
> PROJ mailing list
> PROJ at lists.osgeo.org <mailto:PROJ at lists.osgeo.org>
> https://lists.osgeo.org/mailman/listinfo/proj <https://lists.osgeo.org/mailman/listinfo/proj>
URL: <http://lists.osgeo.org/pipermail/proj/attachments/20230316/2e7a7a4c/attachment-0001.htm>
More information about the PROJ mailing list
