[Pywps-dev] Can't get XML output's execution ( pyWPS + Owslib )
Mariano Kaimakamian marianokaimakamian at suremptec.com.ar
Tue Jan 5 05:41:02 PST 2016
Hello guys:
My name is Mariano and bothering you because I need some guidance; I did a
research but I didn't find any solution.
I'm using pyWPS 3.2.1 (on Ubuntu 12.04.5 LTS) together with Owslib 0.8.9 as
a client, and I'm experiencing some issues when I try to get the response's
xml after pyWPS executes a process; I'm not pretty sure if the problem is
Owslib related but if someone knows something about it, please, let me know.
The process works as it is expected and I can get the output's object that
pyWPS returns (WPSExecution, an owslib's object) if I send the request
omitting the output parameter; however, when I explicitly include that
parameter to get xml generated, the xml is created but without the output.
Take a look, please:
# Setting service and some values
wps = WebProcessingService('http://myDomain/wps', verbose=True)
input_parameters = [
    ("exe_uuid_input", "uuid"), ("pla_uuid_input", "uuid2"),
    ("literal_input", "foobar"), ("sleep", "2"),
    ("sender_address_input", "info at somewhere.com.ar"),
    ("sender_psw_input", "Some input"),
    ("mail_to_input", "info at somewhere.com.ar")
# Execution...
# Accordingly to owslib documentation, "output" is optional identifier
which makes owslib to return the process output as a hyperlink reference...
that means that an xml is generated.
execution = wps.execute(
"proceso_test_2015122_version_test_2015122_4f5a18d2-dfee-4167-a427-ab2e5d7d0bea",
    input_parameters,
output="proceso_test_2015122_version_test_2015122_4f5a18d2-dfee-4167-a427-ab2e5d7d0bea"
Here is the xml created:
<?xml version="1.0" encoding="utf-8"?>
<wps:ExecuteResponse xmlns:wps="http://www.opengis.net/wps/1.0.0"
xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:xlink="
http://www.w3.org/1999/xlink" xmlns:xsi="
http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="
http://schemas.opengis.net/wps/1.0.0/wpsExecute_response.xsd" service="WPS"
version="1.0.0" xml:lang="en-CA"
serviceInstance="?service=WPS&request=GetCapabilities&version=1.0.0"
statusLocation="http://myDomain/wps/outputs/pywps-145199989796.xml">
    <wps:Process wps:processVersion="Version Test 20151221122542.106532">
<ows:Identifier>proceso_test_2015122_version_test_2015122_4f5a18d2-dfee-4167-a427-ab2e5d7d0bea</ows:Identifier>
        <ows:Title>Process: dddee3ad-ebf5-42f0-96b9-48011067ef9f - Version:
Version Test 20151221122542.106532</ows:Title>
        <ows:Abstract><![CDATA[
User: 1
Version: Prueba de eventos y planner]]></ows:Abstract>
    </wps:Process>
    <wps:Status creationTime="2016-01-05T10:18:17Z">
        <wps:ProcessAccepted>Process
accepted</wps:ProcessAccepted>
    </wps:Status>
</wps:ExecuteResponse>
As you can see, there is no output and the status is ProcessAccepted, when
the owslib's object -if I omit the output parameters- confirms the success
of the operation.
That's all guys.
Thanks in advance for your time and for any comment; let me know if you
need more information.
Reagrds,
Mariano
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20160105/22ea46e3/attachment.html>
More information about the pywps-dev mailing list
