[Pywps-dev] Dynamic IPs for polling and results requests.
Luí­s de Sousa luis.de.sousa at protonmail.ch
Mon Oct 17 03:04:59 PDT 2016
Hi Matthieu,
Unfortunately, this is not possible with the configuration files. It is possible to tweak the PyWPS code to behave in that way, but this might not be the simplest way.
My advice is to give a name to that server and keep the entry up to date in your DNS. That is likely the simplest way of running a PyWPS server with a dynamic IP.
Regards,
Luís
-------- Original Message --------
Subject: [Pywps-dev] Dynamic IPs for polling and results requests.
Local Time: 17 October 2016 11:22 AM
UTC Time: 17 October 2016 09:22
To: pywps-dev at lists.osgeo.org
Hello,
I'm using PyWPS 3.2.4 that I containerized into Docker Containers to run
into Mesos Marathon.
The external IP's and ports of my WPS Servers are therefore dynamic for
being assigned by the Marathon framework.
I am able to send a GetCapabilities or Execute requests to these
distributed WPS Servers in the Cluster since I know the 'public' IPs and
ports. However the XML documents sent back to the client by the PyWPS
servers contain 'polling' and 'results' IPs refering to the values set
in 'pywps.cfg' (and not the IP and port used by the client to
communicate with the server).
For example:
[wps]
serveraddress=http://172.16.10.40
[wps]
serveraddress=http://172.16.10.40/wps/wpsoutputs/
Thus, the problem arise once it gets to poll for the end of the execution.
How can I configure PyWPS to force it to provides polling and results
URLs on the same public URLs that the client request?
Matthieu
pywps-dev mailing list
http://lists.osgeo.org/mailman/listinfo/pywps-dev
URL: <http://lists.osgeo.org/pipermail/pywps-dev/attachments/20161017/6f6d6538/attachment.html>
More information about the pywps-dev mailing list
