[Qgis-community-team] help with manual revision
Jürgen E. Fischer jef at norbit.de
Tue May 27 07:12:56 EDT 2008
Hi Werner,
On Tue, 27. May 2008 at 12:12:52 +0200, Werner Macho wrote:
> >BTW if you use pdflatex instead of plain latex you can also uses the
> >PNGs and JPGs directly, without the need to create eps first - and I
> >think PDF is our main target anyway...
> Unfortunately I can't agree with you, as a fresh checkout of the manual
> and commenting out the hyperref line at the end of the .sty leads me to
> a lot of not found graphics like
Using pdflatex I suppose.  That's just because the images are expected
to be in the finalpics directory - so you need to copy them there
upfront (or maybe add all subdirectories to TEXINPUTS).
Jürgen
Jürgen E. Fischer         norBIT GmbH               Tel. +49-4931-918175-0
Dipl.-Inf. (FH)           Rheinstraße 13            Fax. +49-4931-918175-50
Software Engineer         D-26506 Norden               http://www.norbit.de
norBIT Gesellschaft fuer Unternehmensberatung und Informationssysteme mbH
Rheinstrasse 13, 26506 Norden
GF: Jelto Buurman, HR: Amtsgericht Emden, HRB 5502
More information about the Qgis-community-team mailing list
