[Qgis-community-team] Complete information of a point created automatically.
Tim Sutton tim at linfiniti.com
Wed Apr 7 14:41:45 EDT 2010
Hi
This list is for community collaboration on documentation, the web site
etc. You probably want to direct your question to qgis-users mailing
list rather.
Regards
Tim
On 07/04/2010 12:02, Patrice Vetsel wrote:
> I want to use Qgis in situation on the ground. Using a plugin to center
> a map dynamically connected to my gps. My problem is that the creation
> of points on a shapefile layer is very restrictive if you want to fill
> at the same time, the information (1500 points to be created). The idea
> is to have a configurable plugin, which will, after selecting a type,
> fill in items automatically.
> The information is rather repetitive and rather simple. These are street
> lights and often they are the same. Power, nature of bulbs, I'd have to
> input every time. The best would be that the ID is automatically
> incremented and I can select a type (Power 100W/Nature Sodium). After
> selection by clicking on the map to add as many points as you want, and
> the ID field is incremented and power / 100W/Sodium nature are made.
> Have you any ideas?
> Cheers
> Patrice Vetsel
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
More information about the Qgis-community-team mailing list
