[Qgis-community-team] Transifex updates
Tim Sutton tim at linfiniti.com
Wed Mar 20 02:52:02 PDT 2013
Hi
On Wed, Mar 20, 2013 at 11:25 AM, Marie Silvestre
<marie_silvestre at yahoo.fr>wrote:
> Thank you Tim for this major step in the translation process!
> But... the transifex project still doesn't reflects the 1.8 version of the
> manual because the english po files don't seem to be up to date in github
> (it's 3 months old!). I think you should run pre_translate.sh on the
> english doc first.
Ah - I did it in master but I dont think I ever did it in 1.8 - Ill do it
now!
Regards
Tim
> We're almost there!
> Marie
> *De :* Tim Sutton <lists at linfiniti.com>
> *À :* qgis-community <qgis-community-team at lists.osgeo.org>
> *Envoyé le :* Mercredi 20 mars 2013 7h41
> *Objet :* [Qgis-community-team] Transifex updates
> Hi All
> Unless there are other pending issues, I think I am pretty much
> finished configuring and understanding transifex for the
> QGIS-Documentation repo. Here is the current status:
> * The transifex project reflects documentation for v1.8 of the manual
> * Last night I pushed all existing translations up to the project so
> it should reflect the current translation state of each language.
> Please take a look at your language and see if this is indeed the
> case.
> * I've written a script to automate the process of pushing language
> files - this is available under scripts/create-transifex-resources.sh
> and is backported to both 1.8 and master branches.
> * To 'download' translation updates to the git repository Otto or
> other git committers should follow this procedure:
> Things that only need to be done once:
> sudo pip install transifex-client
> cd /tmp
> tx init
> Take the defaults and enter your password when prompted. Note that you
> password is stored in clear text in ~/.transifexrc
> Now go to your local QGIS-Documentation repo and do this everytime you
> want to fetch updates:
> tx pull
> git status
> git add [any new language files)
> git commit -m "Updated i18n resources from Transifex" i18n
> To push any local changes to transifex (for example if you did
> translation work locally using QtLinguist):
> I would greatly appreciate if someone could test the above procedures
> and then transpose the information above into the README.rst file in
> the base of the documentation tree.
> I am now going to go on and do the same for the QGIS Training manual
> and the QGIS application itself.
> Best regards
> Tim
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
> * QGIS programming and support services
> * Mapserver and PostGIS based hosting plans
> * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
> Qgis-community-team mailing list
> Qgis-community-team at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/qgis-community-team
 * QGIS programming services
 * GeoDjango web development
Skype: timlinux Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-community-team/attachments/20130320/4e75f967/attachment-0001.html>
More information about the Qgis-community-team mailing list
